[petsc-dev] Documentation version mismatch?
    Barry Smith
    bsmith at petsc.dev
    Sat Dec 26 14:07:15 CST 2020
  Run release on my machine and it worked correctly. (with bibtex_bibfiles = ['../tex/petsc.bib','../tex/petscapp.bib’] patch). producing 3.14.2
  The last run of latest (release) on readthedocs 2 days ago failed.
  Run my branch of release now on readthedocs and it produces https://docs.petsc.org/en/barry-2020-12-26-docs-add-bibtext-release/ <https://docs.petsc.org/en/barry-2020-12-26-docs-add-bibtext-release/>  which has the 3.14.2 as it should be.
  So the problem could be readthedocs has never properly run on latest (release) past the 3.14.0 version, hence there is not a newer version there. Or something else?
https://gitlab.com/petsc/petsc/-/merge_requests/3513
  BTW: I think the naming is all wrong for readthedocs and we'll need to fix.
     Currently latest -> release   (readthedocs says latest should point to the development version).  I propose we change to
     release -> release version
     master/main -> master/main version
     latest -> master/main version
  Barry
> On Dec 25, 2020, at 4:28 AM, Pierre Jolivet <pierre at joliv.et> wrote:
> Hello,
> https://docs.petsc.org/en/latest/ <https://docs.petsc.org/en/latest/> shows "PETSc 3.14.0 documentation” in the header and footer.
> Shouldn’t it either display 3.14 or 3.14.2?
> Thanks,
> Pierre
> <Screenshot 2020-12-13 at 12.31.24 PM.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201226/abb5d106/attachment.html>
