[petsc-dev] Gfortran Fix for "library not found for -lSystem" macOS Big Sur
Jacob Faibussowitsch
jacob.fai at gmail.com
Wed Dec 23 13:11:26 CST 2020
Follow up, seems that things are more borked than I previously thought. Adding the below to $LIBRARY_PATH makes gfortran work, but MPICH build now fails with:
ld: framework not found OpenCL
collect2: error: ld returned 1 exit status
(Along with 10 different unsigned to signed conversion warnings).
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Dec 22, 2020, at 13:33, Jacob Faibussowitsch <jacob.fai at gmail.com> wrote:
> Hello All,
> If anyone is on macOS and using brew to get gfortran, you may find it suddenly doesn’t work anymore.
> Fix is to add /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/lib to $LIBRARY_PATH in startup shell file, as per this SO post.
> https://apple.stackexchange.com/questions/408999/gfortran-compiler-error-on-mac-os-big-sur <https://apple.stackexchange.com/questions/408999/gfortran-compiler-error-on-mac-os-big-sur>
> Best regards,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201223/14423de5/attachment-0002.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201223/14423de5/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201223/14423de5/attachment-0003.html>
