[petsc-dev] Gfortran Fix for "library not found for -lSystem" macOS Big Sur
Jacob Faibussowitsch jacob.fai at gmail.com
Tue Dec 22 13:33:28 CST 2020
Hello All,
If anyone is on macOS and using brew to get gfortran, you may find it suddenly doesn’t work anymore.
Fix is to add /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/lib to $LIBRARY_PATH in startup shell file, as per this SO post.
https://apple.stackexchange.com/questions/408999/gfortran-compiler-error-on-mac-os-big-sur
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201222/1b0c5f67/attachment.html>
