[petsc-dev] cusparse error
    Mark Adams
    mfadams at lbl.gov
    Wed Dec  9 19:15:19 CST 2020
And this is a Cuda 11 complex build:
https://gitlab.com/petsc/petsc/-/jobs/901108135
On Wed, Dec 9, 2020 at 8:11 PM Mark Adams <mfadams at lbl.gov> wrote:
> My MR is generating an error. Tee error message says cusparse has not been
> initialized, so I added a cuparse init, but I still get the error
> (appended, *adams/landau-gpu-assembly
> <https://gitlab.com/petsc/petsc/-/tree/adams/landau-gpu-assembly>*).  Any
> ideas would be appreciated.
> I am trying to reproduce this on Summit and it fails with a timeout limit
> of 60s, but it only runs for a few seconds (see timers). Any ideas?
> 19:58 adams/landau-gpu-assembly= ~/petsc$ make -f gmakefile test
> search='ksp_ksp_tutorials-ex71_bddc_cusparse'
> PETSC_ARCH=arch-summit-opt-gnu-cuda
> Using MAKEFLAGS: PETSC_ARCH=arch-summit-opt-gnu-cuda
> search=ksp_ksp_tutorials-ex71_bddc_cusparse
>         TEST
> arch-summit-opt-gnu-cuda/tests/counts/ksp_ksp_tutorials-ex71_bddc_cusparse.counts
> not ok ksp_ksp_tutorials-ex71_bddc_cusparse # Exceeded timeout limit of 60
> s
>  ok ksp_ksp_tutorials-ex71_bddc_cusparse # SKIP Command failed so no diff
> #   Summary
> # FAILED ksp_ksp_tutorials-ex71_bddc_cusparse
> # success 0/1 tests (0.0%)
> # failed 1/1 tests (100.0%)
> # todo 0/1 tests (0.0%)
> # skip 0/1 tests (0.0%)
> # Wall clock time for tests: 3 sec
> # Approximate CPU time (not incl. build time): 3.14 sec
> not ok ksp_ksp_tutorials-ex71_bddc_cusparse # Error code: 201
> 2391 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2391># [1]PETSC
> ERROR: --------------------- Error Message
> 2392 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2392># [1]PETSC
> ERROR: GPU error
> 2393 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2393># [1]PETSC
> ERROR: cuSPARSE error 1 (CUSPARSE_STATUS_NOT_INITIALIZED) : initialization
> error
> 2394 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2394># [1]PETSC
> ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for
> trouble shooting.
> 2395 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2395># [1]PETSC
> ERROR: Petsc Development GIT revision: v3.14.2-85-gd60087d GIT Date:
> 2020-12-09 17:49:59 -0500
> 2396 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2396># [1]PETSC
> ERROR: ../ex71 on a named frog by petsc Wed Dec 9 18:41:10 2020
> 2397 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2397># [1]PETSC
> ERROR: Configure options --package-prefix-hash=/home/petsc/petsc-hash-pkgs
> --with-make-test-np=2 COPTFLAGS="-g -O" FOPTFLAGS="-g -O" CXXOPTFLAGS="-g
> -O" --with-scalar-type=complex --with-precision=single
> --with-cuda-dir=/usr/local/cuda-11.0 PETSC_ARCH=arch-ci-linux-cuda11-complex
> 2398 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2398># [1]PETSC
> ERROR: #1 MatConvert_SeqAIJ_SeqAIJCUSPARSE() line 2708 in
> /home/petsc/builds/KFnbdjNX/0/petsc/petsc/src/mat/impls/aij/seq/seqcusparse/
> aijcusparse.cu
> 2399 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2399># [1]PETSC
> ERROR: #2 MatCreate_SeqAIJCUSPARSE() line 2739 in
> aijcusparse.cu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201209/80c50a58/attachment-0001.html>
