[petsc-dev] cusparse error
    Mark Adams
    mfadams at lbl.gov
    Wed Dec  9 19:11:38 CST 2020
My MR is generating an error. Tee error message says cusparse has not been
initialized, so I added a cuparse init, but I still get the error
(appended, *adams/landau-gpu-assembly
<https://gitlab.com/petsc/petsc/-/tree/adams/landau-gpu-assembly>*).  Any
ideas would be appreciated.
I am trying to reproduce this on Summit and it fails with a timeout limit
of 60s, but it only runs for a few seconds (see timers). Any ideas?
19:58 adams/landau-gpu-assembly= ~/petsc$ make -f gmakefile test
search='ksp_ksp_tutorials-ex71_bddc_cusparse'
PETSC_ARCH=arch-summit-opt-gnu-cuda
Using MAKEFLAGS: PETSC_ARCH=arch-summit-opt-gnu-cuda
search=ksp_ksp_tutorials-ex71_bddc_cusparse
        TEST
arch-summit-opt-gnu-cuda/tests/counts/ksp_ksp_tutorials-ex71_bddc_cusparse.counts
not ok ksp_ksp_tutorials-ex71_bddc_cusparse # Exceeded timeout limit of 60 s
 ok ksp_ksp_tutorials-ex71_bddc_cusparse # SKIP Command failed so no diff
#   Summary
# FAILED ksp_ksp_tutorials-ex71_bddc_cusparse
# success 0/1 tests (0.0%)
# failed 1/1 tests (100.0%)
# todo 0/1 tests (0.0%)
# skip 0/1 tests (0.0%)
# Wall clock time for tests: 3 sec
# Approximate CPU time (not incl. build time): 3.14 sec
not ok ksp_ksp_tutorials-ex71_bddc_cusparse # Error code: 201
2391 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2391># [1]PETSC
ERROR: --------------------- Error Message
2392 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2392># [1]PETSC
ERROR: GPU error
2393 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2393># [1]PETSC
ERROR: cuSPARSE error 1 (CUSPARSE_STATUS_NOT_INITIALIZED) : initialization
error
2394 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2394># [1]PETSC
ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
shooting.
2395 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2395># [1]PETSC
ERROR: Petsc Development GIT revision: v3.14.2-85-gd60087d GIT Date:
2020-12-09 17:49:59 -0500
2396 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2396># [1]PETSC
ERROR: ../ex71 on a named frog by petsc Wed Dec 9 18:41:10 2020
2397 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2397># [1]PETSC
ERROR: Configure options --package-prefix-hash=/home/petsc/petsc-hash-pkgs
--with-make-test-np=2 COPTFLAGS="-g -O" FOPTFLAGS="-g -O" CXXOPTFLAGS="-g
-O" --with-scalar-type=complex --with-precision=single
--with-cuda-dir=/usr/local/cuda-11.0 PETSC_ARCH=arch-ci-linux-cuda11-complex
2398 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2398># [1]PETSC
ERROR: #1 MatConvert_SeqAIJ_SeqAIJCUSPARSE() line 2708 in
/home/petsc/builds/KFnbdjNX/0/petsc/petsc/src/mat/impls/aij/seq/seqcusparse/
aijcusparse.cu
2399 <https://gitlab.com/petsc/petsc/-/jobs/901108135#L2399># [1]PETSC
ERROR: #2 MatCreate_SeqAIJCUSPARSE() line 2739 in
aijcusparse.cu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201209/73e17638/attachment.html>
