[petsc-dev] Merge request error
Satish Balay
balay at mcs.anl.gov
Sat Dec 5 14:05:21 CST 2020
Ah - ok.
Everyone does not have write access to the petsc repo. The process for this usecase is:
- create a gitlab account
- create a fork of the petsc repo [in your gitlab space]
- push the 'bug fix' branch to your fork [not petsc repo]
- create a merge request from your-repo/branch to petsc-repo/master [or release branch - if appropriate]
Satish
On Sat, 5 Dec 2020, Ali Reza Khaz'ali wrote:
> Dear Satish,
> I tried to use "git push" to push my branch to the origin (i.e. mainstream
> PETSc repo). However, instead of receiving the URL for creating a merge
> request, I got the following error:
> fatal: unable to access 'https://gitlab.com/petsc/petsc.git/': The requested
> URL returned error: 403
> I supposed that the error was because of my unfamiliarity with GitLab.
> Therefore I tried to use GitLab web interface at:
> https://gitlab.com/petsc/petsc/-/merge_requests/new
> which is giving me a 404 error.
> Many thanks,
> Ali
> -----Original Message-----
> From: Satish Balay <balay at mcs.anl.gov>
> Sent: Saturday, December 05, 2020 8:32 PM
> To: Ali Reza Khaz'ali <arkhazali at iut.ac.ir>
> Cc: 'petsc-dev' <petsc-dev at mcs.anl.gov>
> Subject: Re: [petsc-dev] Merge request error
> The relevant instructions on creating a merge request from a fork are at
> https://docs.petsc.org/en/latest/developers/integration/
> Would it be possible to provide details on how you tried to create a merge
> request - and what exactly failed?
> Satish
> > Hi,
> > I want to fix an issue in petscsys.h that prevents the code from being
> > compiled by icl on Windows. However, I cannot create a merge request,
> > and GitLab web interface link shows a 404 error. I would be grateful
> > if you could provide guidance on the matter.
> > Best wishes,
> > Dr. Ali Reza Khaz'ali
> > Assistant Professor of Petroleum Engineering & Director of Student
> > Affairs,
> > Department of Chemical Engineering
> > Isfahan University of Technology
> > Isfahan, Iran
