[petsc-dev] Merge request error
Ali Reza Khaz'ali
arkhazali at iut.ac.ir
Sat Dec 5 12:50:05 CST 2020
Dear Satish,
Thanks a lot. Also, many thanks for maintaining such great library.
Best wishes,
Ali
-----Original Message-----
Sent: Saturday, December 05, 2020 8:52 PM
To: Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov>
Cc: Ali Reza Khaz'ali <arkhazali at iut.ac.ir>; 'hossein barati' <hossein.barati72 at gmail.com>; rohaldinmiri at iust.ac.ir
Subject: Re: [petsc-dev] Merge request error
I've manually added this patch - and created a merge request at https://gitlab.com/petsc/petsc/-/merge_requests/3462
Satish
On Sat, 5 Dec 2020, Satish Balay via petsc-dev wrote:
> Its best to send the patch file as attachment - so that the format is preserved.
> Satish
> On Sat, 5 Dec 2020, Ali Reza Khaz'ali wrote:
> > Dear Matt,
> > Thanks a lot for your kind answer. It is just a simple fix for Pragma directives, which are a bit different for windows icl.
> > diff --git a/include/petscsys.h b/include/petscsys.h
> > index 1b414e7dce..381ad1c0cf 100644
> > --- a/include/petscsys.h
> > +++ b/include/petscsys.h
> > @@ -388,8 +388,10 @@ M*/
> > # define PetscPragmaSIMD _Pragma("vector")
> > #elif defined(__GNUC__) && __GNUC__ >= 5 && !defined(__PGI)
> > # define PetscPragmaSIMD _Pragma("GCC ivdep")
> > -#elif defined(_OPENMP) && _OPENMP >= 201307
> > +#elif defined(_OPENMP) && _OPENMP >= 201307 && !defined(_WIN32)
> > # define PetscPragmaSIMD _Pragma("omp simd")
> > +#elif defined(_OPENMP) && _OPENMP >= 201307 && defined(_WIN32)
> > +# define PetscPragmaSIMD __pragma(omp simd)
> > #elif defined(PETSC_HAVE_CRAY_VECTOR)
> > # define PetscPragmaSIMD _Pragma("_CRI ivdep")
> > #else
> > Best wishes,
> > Ali
> > From: Matthew Knepley <knepley at gmail.com>
> > Sent: Saturday, December 05, 2020 7:10 PM
> > To: Ali Reza Khaz'ali <arkhazali at iut.ac.ir>
> > Cc: petsc-dev <petsc-dev at mcs.anl.gov>
> > On Sat, Dec 5, 2020 at 4:12 AM Ali Reza Khaz'ali <arkhazali at iut.ac.ir <mailto:arkhazali at iut.ac.ir> > wrote:
> > Hi,
> > I want to fix an issue in petscsys.h that prevents the code from being compiled by icl on Windows. However, I cannot create a merge request, and GitLab web interface link shows a 404 error. I would be grateful if you could provide guidance on the matter.
> > Hi,
> > This would be a grat contribution. I see two ways to solve this:
> > 1) Are you trying to create a Merge Request from your fork of PETSc? Just making sure, because you might not have permission for an MR from the PETSc repo itself.
> > 2) If Gitlab is just not working, you can send your diff to me, and I will check it in under your name.
> > Thanks,
> > Matt
> > Best wishes,
> > Dr. Ali Reza Khaz’ali
> > Assistant Professor of Petroleum Engineering & Director of Student Affairs,
> > Department of Chemical Engineering
> > Isfahan University of Technology
> > Isfahan, Iran
