[petsc-dev] Merge request error
Ali Reza Khaz'ali
arkhazali at iut.ac.ir
Sat Dec 5 12:46:09 CST 2020
Dear Satish,
Thanks for your considerations. The patched file is attached.
Best wishes,
Ali
-----Original Message-----
Sent: Saturday, December 05, 2020 8:47 PM
To: Ali Reza Khaz'ali <arkhazali at iut.ac.ir>
Cc: 'Matthew Knepley' <knepley at gmail.com>; 'hossein barati' <hossein.barati72 at gmail.com>; 'petsc-dev' <petsc-dev at mcs.anl.gov>; rohaldinmiri at iust.ac.ir
Subject: Re: [petsc-dev] Merge request error
Its best to send the patch file as attachment - so that the format is preserved.
Satish
On Sat, 5 Dec 2020, Ali Reza Khaz'ali wrote:
> Dear Matt,
> Thanks a lot for your kind answer. It is just a simple fix for Pragma directives, which are a bit different for windows icl.
> diff --git a/include/petscsys.h b/include/petscsys.h
> index 1b414e7dce..381ad1c0cf 100644
> --- a/include/petscsys.h
> +++ b/include/petscsys.h
> @@ -388,8 +388,10 @@ M*/
> # define PetscPragmaSIMD _Pragma("vector")
> #elif defined(__GNUC__) && __GNUC__ >= 5 && !defined(__PGI)
> # define PetscPragmaSIMD _Pragma("GCC ivdep")
> -#elif defined(_OPENMP) && _OPENMP >= 201307
> +#elif defined(_OPENMP) && _OPENMP >= 201307 && !defined(_WIN32)
> # define PetscPragmaSIMD _Pragma("omp simd")
> +#elif defined(_OPENMP) && _OPENMP >= 201307 && defined(_WIN32)
> +# define PetscPragmaSIMD __pragma(omp simd)
> #elif defined(PETSC_HAVE_CRAY_VECTOR)
> # define PetscPragmaSIMD _Pragma("_CRI ivdep")
> #else
> Best wishes,
> Ali
> From: Matthew Knepley <knepley at gmail.com>
> Sent: Saturday, December 05, 2020 7:10 PM
> Cc: petsc-dev <petsc-dev at mcs.anl.gov>
> On Sat, Dec 5, 2020 at 4:12 AM Ali Reza Khaz'ali <arkhazali at iut.ac.ir <mailto:arkhazali at iut.ac.ir> > wrote:
> Hi,
> I want to fix an issue in petscsys.h that prevents the code from being compiled by icl on Windows. However, I cannot create a merge request, and GitLab web interface link shows a 404 error. I would be grateful if you could provide guidance on the matter.
> Hi,
> This would be a grat contribution. I see two ways to solve this:
> 1) Are you trying to create a Merge Request from your fork of PETSc? Just making sure, because you might not have permission for an MR from the PETSc repo itself.
> 2) If Gitlab is just not working, you can send your diff to me, and I will check it in under your name.
> Thanks,
> Matt
> Best wishes,
> Dr. Ali Reza Khaz’ali
> Assistant Professor of Petroleum Engineering & Director of Student Affairs,
> Department of Chemical Engineering
> Isfahan University of Technology
> Isfahan, Iran
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201205/ef33cc9b/attachment-0001.h>
