[petsc-dev] Pause-for-approval Pipelines?
Satish Balay
balay at mcs.anl.gov
Thu Aug 27 19:19:01 CDT 2020
[want to respond to this part]
On Thu, 27 Aug 2020, Barry Smith wrote:
> Generally I like to pass the Pipeline before making a PR.
This is api/web pipeline - and continues to work as before.
> So the test on creating a new MR is annoying.
There is no change wrt MR creation [wrt the merge_request pipelines feature]
> Yes after the initial MR I might be able to release the paused job in lieu of starting pipelines fresh.
Yes - and I think its is useful to switch form api/web to merge_request pipeline - once the MR is created.
> It would be nice to send some pushes that don't trigger a pipeline start at all because I know I don't need one. Maybe that is possible, I'll need to investigate.
Yes - this is useful - and it will avoid the extra 'blocked' pipelines listing [even-though they are mostly no-op -aka pre stage only - and should be ignored].
Satish
