[petsc-dev] Configure won't find python
    Jacob Faibussowitsch
    jacob.fai at gmail.com
    Sat Apr 18 13:47:14 CDT 2020
> They won't have /usr/bin/python unless they explicitly install
> python-is-python3.  Since no packages should depend on
> python-is-python3, only Python users who work with unpackaged software
> (Python developers and developer-adjacents) *and* learn about it will
> have it.  It means PETSc should work with systems that don't have python
> in their path.
Perhaps adopting valgrinds model might be more appropriate in that case?
They require you run autogen.sh (which I don’t know that we need), and then configure which runs in shell and does the configure. We don’t necessarily have to do all of our configure in shell, just find a suitable python and call configure_in_python.py. I don’t know how they get around not having to chmod+x the shell scripts however, maybe because configure.sh has the shebang (!# /usr/bin/env sh) in it already?
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Apr 18, 2020, at 1:15 PM, Jed Brown <jed at jedbrown.org> wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
>>>> From the page:
>>>  make sure package doesn't call python at build- or compile time (as there won't be a python package and no python command in bullseye, only python3.)
>> Sure this makes sense for building distro packages - so that they have correct dependencies.
>> But its not indicative of user install not having /usr/bin/python.
> in their path.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200418/2dbaa54d/attachment.html>
