[petsc-dev] Configure won't find python
    Jacob Faibussowitsch
    jacob.fai at gmail.com
    Fri Apr 17 23:43:01 CDT 2020
On macOS /usr/bin/python still defaults to:
$/usr/bin/python
WARNING: Python 2.7 is not recommended.
This version is included in macOS for compatibility with legacy software.
Future versions of macOS will not include Python 2.7.
Instead, it is recommended that you transition to using 'python3' from within Terminal.
Python 2.7.16 (default, Feb 29 2020, 01:55:37)
[GCC 4.2.1 Compatible Apple LLVM 11.0.3 (clang-1103.0.29.20) (-macos10.15-objc- on darwin
Type "help", "copyright", "credits" or "license" for more information.
/usr/bin/env python also points to the same python 2.7
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Apr 17, 2020, at 11:31 PM, Jed Brown <jed at jedbrown.org> wrote:
> Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>>>> Given that python2 has gone the way of the dodo perhaps petsc should be looking for python3 over python2.
>> I'm not sure what would be common across distros/OSes wrt /usr/bin/python - one shouldn't assume this is always python2 [and that it won't exist for python3 only installs]
>> I have:
>> balay at sb /home/balay
>> $ /usr/bin/python --version
>> Python 3.7.6
> My distro's /usr/bin/python has been python3 since, I believe, 2011.
> That said, an executable named python3 also exists at that path.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200417/19cf0fa6/attachment.html>
