[petsc-dev] CMake on Catalina
Fri Apr 17 20:59:05 CDT 2020
I just did the following build on 3 of the OSX test boxes. [with brew gcc etc..]
balay at jpro^~/petsc(maint) $ ./configure --with-mpi=0 CC=gcc-9 CXX=g++-9 FC=gfortran-9 --download-cmake
Worked on 2 of them.
The 3rd failed with PETSc configure errors.
As far as I can tell - all 3 systems should be the same [latest, OSX, xcode updated at the same time, all have command line tools installed etc..] - but they are not  - and I don't understand why.
Satish
TEST checkLibC from config.setCompilers(/Users/balay/petsc/config/BuildSystem/config/setCompilers.py:1510)
TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1510)
  Test whether we need to explicitly include libc in shared linking
       - Mac OSX requires an explicit reference to libc for shared linking
Running Executable WITHOUT threads to time it out
Executing: gcc-9 -c -o /var/folders/xk/v0fd809s2y7b3x8bp05l2nww0000gq/T/petsc-GRzCKQ/config.setCompilers/conftest.o -I/var/folders/xk/v0fd809s2y7b3x8bp05l2nww0000gq/T/petsc-GR\
zCKQ/config.setCompilers   /var/folders/xk/v0fd809s2y7b3x8bp05l2nww0000gq/T/petsc-GRzCKQ/config.setCompilers/conftest.c
Possible ERROR while running compiler: exit code 1
stderr:
In file included from /Library/Developer/CommandLineTools/SDKs/MacOSX10.15.sdk/usr/include/sys/wait.h:110,
                 from /Library/Developer/CommandLineTools/SDKs/MacOSX10.15.sdk/usr/include/stdlib.h:66,
                 from /var/folders/xk/v0fd809s2y7b3x8bp05l2nww0000gq/T/petsc-GRzCKQ/config.setCompilers/conftest.c:3:
/Library/Developer/CommandLineTools/SDKs/MacOSX10.15.sdk/usr/include/sys/resource.h: In function 'getiopolicy_np':
/Library/Developer/CommandLineTools/SDKs/MacOSX10.15.sdk/usr/include/sys/resource.h:443:34: error: expected declaration specifiers before '__OSX_AVAILABLE_STARTING'
  443 | int     getiopolicy_np(int, int) __OSX_AVAILABLE_STARTING(__MAC_10_5, __IPHONE_2_0);
/Library/Developer/CommandLineTools/SDKs/MacOSX10.15.sdk/usr/include/sys/resource.h:449:39: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__OSX_AVAILABLE_STA\
RTING'
  449 | int     setiopolicy_np(int, int, int) __OSX_AVAILABLE_STARTING(__MAC_10_5, __IPHONE_2_0);
In file included from /Library/Developer/CommandLineTools/SDKs/MacOSX10.15.sdk/usr/include/libkern/_OSByteOrder.h:66,
                 from /Library/Developer/CommandLineTools/SDKs/MacOSX10.15.sdk/usr/include/sys/_endian.h:130,
                 from /Library/Developer/CommandLineTools/SDKs/MacOSX10.15.sdk/usr/include/i386/endian.h:99,
                 from /Library/Developer/CommandLineTools/SDKs/MacOSX10.15.sdk/usr/include/machine/endian.h:35,
                 from /Library/Developer/CommandLineTools/SDKs/MacOSX10.15.sdk/usr/include/sys/wait.h:186,
On Fri, 17 Apr 2020, Matthew Knepley wrote:
> CMake itself. On Catalina, the SSL/TLS headers use special syntax that only
> Clang can parse.
> You should check for this in the configure stage, but they do not. The
> response for the error
> reports on the CMake Github was that you should not be building on Apple
> with something that
> won't parse some of the Apple headers. This seems like an abdication of
> responsibility to me.
>    Matt
> On Fri, Apr 17, 2020 at 7:07 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > Build cmake or a package using cmake?
> > balay at sb /home/balay/petsc (master=)
> > $ grep download-cmake config/examples/arch-ci-osx-*
> > config/examples/arch-ci-osx-cxx-cmplx-pkgs-dbg.py:  '--download-cmake=1',
> > config/examples/arch-ci-osx-cxx-pkgs-opt.py:  '--download-cmake=1',
> > config/examples/arch-ci-osx-xsdk-opt.py:  '--download-cmake=1',
> > download-cmake works fine on all our OSX test boxes [they are on Catalina]
> > balay at kpro petsc % sw_vers
> > ProductName:    Mac OS X
> > ProductVersion: 10.15.3
> > BuildVersion:   19D76
> > And I have cmake installed via brew on these boxes.
> > Satish
> > > I have just spent hours trying to build CMake on Catalina. This is not a
> > > configure system. I finally had to just comment out a bunch of source
> > files
> > > in their build system, and define out a bunch of code. I can't believe
> > this
> > > works anywhere.
> > >    Matt
