[petsc-dev] CUDA + OMP make error
    Junchao Zhang
    junchao.zhang at gmail.com
    Mon Apr 13 16:43:15 CDT 2020
Mark,
 I saw you had "--with-threadsaftey --with-log=0".  Do you really want to
call petsc from multiple threads (in contrast to letting petsc call
other libraries, e.g., BLAS, doing multithreading)?  If not, you can
drop --with-threadsaftey.
 I have https://gitlab.com/petsc/petsc/-/merge_requests/2714 that should
fix your original compilation errors.
--Junchao Zhang
On Mon, Apr 13, 2020 at 2:07 PM Mark Adams <mfadams at lbl.gov> wrote:
> https://www.mcs.anl.gov/petsc/miscellaneous/petscthreads.html
> and I see this on my Mac:
> 14:23 1 mark/feature-xgc-interface-rebase *= ~/Codes/petsc$
> ../arch-macosx-gnu-O-omp.py
>              Configuring PETSc to compile on your system
>                Warning: PETSC_ARCH from environment does not match
> command-line or name of script.
>                                      Warning: Using from command-line or
> name of script: arch-macosx-gnu-O-omp, ignoring environment:
> arch-macosx-gnu-g
>          TESTING: configureLibraryOptions from
> PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:37)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Must use --with-log=0 with --with-threadsafety
> On Mon, Apr 13, 2020 at 2:54 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> On Mon, Apr 13, 2020 at 12:06 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> BTW, I can build on SUMMIT with logging and OMP, apparently. I also seem
>>> to be able to build with debugging. Both of which are not allowed according
>>> the the docs. I am puzzled.
>>  What are "the docs"?
>>> On Mon, Apr 13, 2020 at 12:05 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>> I think the problem is that you have to turn off logging with openmp
>>>> and the (newish) GPU timers did not protect their timers.
>>>> I don't see a good reason to require logging be turned off with OMP. We
>>>> could use PETSC_HAVE_THREADSAFETY to protect logs that we care about (eg,
>>>> in MatSetValues) and as users discover more things that they want to call
>>>> in an OMP thread block, then tell them to turn logging off and we will fix
>>>> it when we can.
>>>> Any thoughts on the idea of letting users keep logging with openmp?
>>>> On Mon, Apr 13, 2020 at 11:40 AM Junchao Zhang <junchao.zhang at gmail.com>
>>>> wrote:
>>>>> Yes. Looks we need to include petsclog.h. Don't know why OMP
>>>>> triggered the error.
>>>>> --Junchao Zhang
>>>>> On Mon, Apr 13, 2020 at 9:59 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> Should I do an MR to fix this?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200413/3127eb24/attachment-0001.html>
