[petsc-dev] failed rebase
Mark Adams mfadams at lbl.gov
Fri Apr 3 11:38:46 CDT 2020
I am in no hurry to rebase.
This branch added just a few fortran stubs, so Plex is clearly about to
bust. (Matt has a branch with more Fortran stubs)
I can wait until it's in master.
On Fri, Apr 3, 2020 at 12:06 PM Satish Balay via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> On Fri, 3 Apr 2020, Satish Balay via petsc-dev wrote:
> > So run bfort on 10 files at a time?
> The following is working..
> Satish
> $ git diff
> diff --git a/lib/petsc/bin/maint/generatefortranstubs.py
> b/lib/petsc/bin/maint/generatefortranstubs.py
> index 329fcb5b6f..351cf71257 100755
> --- a/lib/petsc/bin/maint/generatefortranstubs.py
> +++ b/lib/petsc/bin/maint/generatefortranstubs.py
> @@ -178,8 +178,10 @@ def processDir(petscdir, bfort, verbose, dirpath,
> dirnames, filenames):
>                 '-mpi', '-shortargname', '-ferr', '-ptrprefix Petsc',
> '-ptr64 PETSC_USE_POINTER_CONVERSION',
>                 '-fcaps PETSC_HAVE_FORTRAN_CAPS', '-fuscore
> PETSC_HAVE_FORTRAN_UNDERSCORE',
>                 '-f90mod_skip_header','-f90modfile','f90module.f90']
> -    cmd =
> 'BFORT_CONFIG_PATH='+os.path.join(petscdir,'lib','petsc','conf')+'
> '+bfort+' '+' '.join(options+newls)
> -    output = check_output(cmd, cwd=dirpath, shell=True,
> stderr=subprocess.STDOUT)
> +    split_ct = 10
> +    for i in range(0, len(newls), split_ct):
> +      cmd =
> '+bfort+' '+' '.join(options+newls[i:i+split_ct])
> +      output = check_output(cmd, cwd=dirpath, shell=True,
>      FixDir(petscdir,outdir,verbose)
>    # remove from list of subdirectories all directories without source code
> balay at sb /home/balay/petsc ((752ef57468...) *)
> $ time lib/petsc/bin/maint/generatefortranstubs.py bfort
> real    0m3.514s
> user    0m2.055s
> sys     0m1.642s
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200403/2f5eca0a/attachment.html>
