[petsc-dev] failed rebase
Fri Apr 3 11:06:20 CDT 2020
On Fri, 3 Apr 2020, Satish Balay via petsc-dev wrote:
> So run bfort on 10 files at a time?
The following is working..
Satish
$ git diff
diff --git a/lib/petsc/bin/maint/generatefortranstubs.py b/lib/petsc/bin/maint/generatefortranstubs.py
index 329fcb5b6f..351cf71257 100755
--- a/lib/petsc/bin/maint/generatefortranstubs.py
+++ b/lib/petsc/bin/maint/generatefortranstubs.py
@@ -178,8 +178,10 @@ def processDir(petscdir, bfort, verbose, dirpath, dirnames, filenames):
                '-mpi', '-shortargname', '-ferr', '-ptrprefix Petsc', '-ptr64 PETSC_USE_POINTER_CONVERSION',
                '-fcaps PETSC_HAVE_FORTRAN_CAPS', '-fuscore PETSC_HAVE_FORTRAN_UNDERSCORE',
                '-f90mod_skip_header','-f90modfile','f90module.f90']
-    cmd = 'BFORT_CONFIG_PATH='+os.path.join(petscdir,'lib','petsc','conf')+' '+bfort+' '+' '.join(options+newls)
-    output = check_output(cmd, cwd=dirpath, shell=True, stderr=subprocess.STDOUT)
+    split_ct = 10
+    for i in range(0, len(newls), split_ct):
+      cmd = 'BFORT_CONFIG_PATH='+os.path.join(petscdir,'lib','petsc','conf')+' '+bfort+' '+' '.join(options+newls[i:i+split_ct])
+      output = check_output(cmd, cwd=dirpath, shell=True, stderr=subprocess.STDOUT)
     FixDir(petscdir,outdir,verbose)
   # remove from list of subdirectories all directories without source code
balay at sb /home/balay/petsc ((752ef57468...) *)
$ time lib/petsc/bin/maint/generatefortranstubs.py bfort
real	0m3.514s
user	0m2.055s
sys	0m1.642s
