[petsc-dev] failed rebase
Mark Adams mfadams at lbl.gov
Fri Apr 3 08:55:56 CDT 2020
Satish, I tried again from scratch see the same thing.
I pushed this.
Thanks
09:35 mark/feature-xgc-interface-rebase= ~/Codes/petsc$ git rebase
origin/master
First, rewinding head to replay your work on top of it...
Applying: starting rebase branch
Using index info to reconstruct a base tree...
M       include/petsc/private/dmpleximpl.h
M       include/petscdmplex.h
M       src/dm/impls/plex/makefile
.git/rebase-apply/patch:2620: trailing whitespace.
      for (d=0;d<src->dim;d++) *pp++ = src->df[d][s][idx];
warning: 1 line adds whitespace errors.
Falling back to patching base and 3-way merge...
Auto-merging src/dm/impls/plex/makefile
Auto-merging include/petscdmplex.h
CONFLICT (content): Merge conflict in include/petscdmplex.h
Auto-merging include/petsc/private/dmpleximpl.h
error: Failed to merge in the changes.
Patch failed at 0001 starting rebase branch
hint: Use 'git am --show-current-patch' to see the failed patch
Resolve all conflicts manually, mark them as resolved with
"git add/rm <conflicted_files>", then run "git rebase --continue".
You can instead skip this commit: run "git rebase --skip".
To abort and get back to the state before "git rebase", run "git rebase
--abort".
09:36 1 mark/feature-xgc-interface-rebase *+|REBASE 1/19 ~/Codes/petsc$ vi
09:37 mark/feature-xgc-interface-rebase *+|REBASE 1/19 ~/Codes/petsc$ git
add include/petscdmplex.h
09:37 mark/feature-xgc-interface-rebase +|REBASE 1/19 ~/Codes/petsc$ git
rebase --continue
Applying: manual merge
Applying: RE test
Applying: remove Ehat
Applying: clean up interface, redo regression tests, found false negatives
Applying: change Ec
Applying: tweek griding
Applying: clean up, working on impurity injection
Applying: fixed quench and pulse test
Applying: hardwired CUDA kernel for DIM, added presolve in ex11
Applying: added guard
Applying: starting to get E field added
Applying: doc
Applying: fix test params
Applying: remove comment
Applying: updated test syntax
Applying: cleaned up flags
Applying: fixed soruce bug
09:37 mark/feature-xgc-interface-rebase<> ~/Codes/petsc$ rm -fr
arch-macosx-gnu-g/
09:38 mark/feature-xgc-interface-rebase<> ~/Codes/petsc$
../arch-macosx-gnu-g.py
             Configuring PETSc to compile on your system
                                                   ***** WARNING: You have
an older version of Gnu make, it will work,
                         but may not support all the parallel testing
options. You can install the
     latest Gnu make with your package manager, such as brew or macports,
or use
                                                         the
--download-make option to get the latest Gnu make *****
                                                   Trying to download git://
https://bitbucket.org/petsc/pkg-sowing.git for SOWING
                                                   Running configure on
SOWING; this may take several minutes
                                                   Running make on SOWING;
                                                   Running make install on
                                             TESTING: checkSharedLibrary
from config.packages.sowing(config/BuildSystem/config/package.py:926)
        CONFIGURATION CRASH  (Please send configure.log to
petsc-maint at mcs.anl.gov)
09:40 1 mark/feature-xgc-interface-rebase<> ~/Codes/petsc$
On Fri, Apr 3, 2020 at 8:17 AM Mark Adams <mfadams at lbl.gov> wrote:
> On Thu, Apr 2, 2020 at 11:05 PM Satish Balay <balay at mcs.anl.gov> wrote:
>> My OS build also went through. Looks like you haven't pushed [force
>> update] this branch - so I'm testing with something totally different.
> Yes, I have a <> after a rebase.  Do you want me to push it? Or should I
> just start over? I thought I started with a clean version of my code from
> the repo.
> Thanks,
>> So likely something in your rebased sources is causing bfort to fail..
>> Satish
>> On Thu, 2 Apr 2020, Mark Adams wrote:
>> > I see:
>> > 22:46 128 mark/feature-xgc-interface-rebase<> ~/Codes/petsc$ git status
>> > On branch mark/feature-xgc-interface-rebase
>> > Your branch and 'origin/mark/feature-xgc-interface-rebase' have
>> diverged,
>> > and have 130 and 18 different commits each, respectively.
>> >   (use "git pull" to merge the remote branch into yours)
>> > Untracked files:
>> >   (use "git add <file>..." to include in what will be committed)
>> >         out2.txt
>> >         src/dm/impls/plex/examples/tutorials/Landau/
>> > On Thu, Apr 2, 2020 at 10:45 PM Mark Adams <mfadams at lbl.gov> wrote:
>> > > On Thu, Apr 2, 2020 at 10:33 PM Satish Balay <balay at mcs.anl.gov>
>> wrote:
>> > >> Is this branch mark/feature-xgc-interface-rebase pushed?
>> > > yes.
>> > >> I had done a build with the current state of it - and the build went
>> > >> through fine. This was on linux.
>> > >> Will try OSX now.
>> > >> Satish
>> > >> > Note, when I rebased I got one conflict, in a header where I added
>> > >> stuff at
>> > >> > the end and master did also so I just kept them both and continued.
>> > >> > Other than that it was a clean rebase.
>> > >> > On Thu, Apr 2, 2020 at 10:15 PM Mark Adams <mfadams at lbl.gov>
>> wrote:
>> > >> > > On Thu, Apr 2, 2020 at 9:32 PM Satish Balay <balay at mcs.anl.gov>
>> > >> wrote:
>> > >> > >> can you try this in a local clone [same branch] and see if that
>> > >> works?
>> > >> > >> cd /Users/markadams/Codes
>> > >> > >> git clone petsc petsc-test
>> > >> > >> cd petsc-test
>> > >> > >> ./configure ...
>> > >> > >> Satish
>> > >> > >> > I tried to rebase mark/feature-xgc-interface-rebase with
>> master
>> > >> and I
>> > >> > >> get
>> > >> > >> > this.
>> > >> > >> > I of course deleted the arch directory.
>> > >> > >> > Thanks,
>> > >> > >> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200403/8c24d141/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200403/8c24d141/attachment-0001.obj>
