[petsc-dev] failed rebase
    Mark Adams
    mfadams at lbl.gov
    Fri Apr  3 07:17:26 CDT 2020
On Thu, Apr 2, 2020 at 11:05 PM Satish Balay <balay at mcs.anl.gov> wrote:
> My OS build also went through. Looks like you haven't pushed [force
> update] this branch - so I'm testing with something totally different.
Yes, I have a <> after a rebase.  Do you want me to push it? Or should I
just start over? I thought I started with a clean version of my code from
the repo.
> So likely something in your rebased sources is causing bfort to fail..
> Satish
> On Thu, 2 Apr 2020, Mark Adams wrote:
> > I see:
> > 22:46 128 mark/feature-xgc-interface-rebase<> ~/Codes/petsc$ git status
> > On branch mark/feature-xgc-interface-rebase
> > Your branch and 'origin/mark/feature-xgc-interface-rebase' have diverged,
> > and have 130 and 18 different commits each, respectively.
> >   (use "git pull" to merge the remote branch into yours)
> > Untracked files:
> >   (use "git add <file>..." to include in what will be committed)
> >         out2.txt
> >         src/dm/impls/plex/examples/tutorials/Landau/
> > On Thu, Apr 2, 2020 at 10:45 PM Mark Adams <mfadams at lbl.gov> wrote:
> > > On Thu, Apr 2, 2020 at 10:33 PM Satish Balay <balay at mcs.anl.gov>
> wrote:
> > >> Is this branch mark/feature-xgc-interface-rebase pushed?
> > > yes.
> > >> I had done a build with the current state of it - and the build went
> > >> through fine. This was on linux.
> > >> Will try OSX now.
> > >> Satish
> > >> > Note, when I rebased I got one conflict, in a header where I added
> > >> stuff at
> > >> > the end and master did also so I just kept them both and continued.
> > >> > Other than that it was a clean rebase.
> > >> > On Thu, Apr 2, 2020 at 10:15 PM Mark Adams <mfadams at lbl.gov> wrote:
> > >> > > On Thu, Apr 2, 2020 at 9:32 PM Satish Balay <balay at mcs.anl.gov>
> > >> wrote:
> > >> > >> can you try this in a local clone [same branch] and see if that
> > >> works?
> > >> > >> cd /Users/markadams/Codes
> > >> > >> git clone petsc petsc-test
> > >> > >> cd petsc-test
> > >> > >> ./configure ...
> > >> > >> Satish
> > >> > >> > I tried to rebase mark/feature-xgc-interface-rebase with master
> > >> and I
> > >> > >> get
> > >> > >> > this.
> > >> > >> > I of course deleted the arch directory.
> > >> > >> > Thanks,
> > >> > >> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200403/da44f88e/attachment-0001.html>
