[petsc-dev] git repo branches housekeeping
Balay, Satish
balay at mcs.anl.gov
Mon Sep 30 10:39:27 CDT 2019
ref: https://lists.mcs.anl.gov/pipermail/petsc-dev/2017-September/021359.html
I've deleted all deveopment branches that are already merged into
maint (v3.12) from https://gitlab.com/petsc/petsc
However if you wish to remove these branches from your clone - it has
to be done manually (in each clone).
To get this list of branches to delete - you can do:
git branch --merged v3.12 |egrep -v " (maint|master|next)" > branches_to_delete
After *verifying* the list is correct - and ok to delete - they can be
deleted with:
git branch -d `cat branches_to_delete`
And to sync the [deleted] remote branch list info - you can do:
git fetch -p
For more housekeeping - look at the remaining local and remote
branches and figure-out what to do. [perhaps some of them are
intermediate branches during rebase - or abandoned features that
should be deleted. And with the new workflow - we could have branches
squashed during merge - that would be equivalent to rebased branches -
that should be deleted]. For my branches - I would do:
git branch
git branch -r |grep balay
Satish
reference for self:
$ git branch -r --merged v3.12 |egrep -v origin/\(maint\|master\|next\) |sed -e s%origin/%:% > remote_branches_to_delete
$ git push -u origin `cat remote_branches_to_delete` | tee delete_branches.log
To gitlab.com:petsc/petsc.git
- [deleted] 360-ci-error-tracker
- [deleted] BarryFSmith/add-information-on-running-usrbinbash-lo-1561921668145
- [deleted] Fande-Kong/feature-maij-hmg
- [deleted] Fande-Kong/fix_clean_hash_table
- [deleted] Junchao-Zhang/part2tex-edited-online-with-bitbucket-1563223298438
- [deleted] Patrick-Sanan/shellpcc-edited-online-with-bitbucket-1564998221921
- [deleted] Patrick-Sanan/stagutilsc-edited-online-with-bitbucket-1560787739826
- [deleted] Stefano-Zampini/taosolver_hjc-edited-online-with-bitbuck-1562852734303
- [deleted] balay/add-MatBlockMatSetPreallocation-API/maint
- [deleted] balay/add-cxx-dialect-flgs-to-petscconf_h
- [deleted] balay/add-mpi-exec-check/maint
- [deleted] balay/build-update-datafiles
- [deleted] balay/check-tmp-noexec
- [deleted] balay/exodusii-missing-netcdf-pnetcdf-dir
- [deleted] balay/fix-configure-non-english-text-handling/maint
- [deleted] balay/fix-errorcheck-with-batch-hdf5-dir
- [deleted] balay/fix-ex-for-64idx
- [deleted] balay/fix-force
- [deleted] balay/fix-msys2-link
- [deleted] balay/fix-msys2-link-2
- [deleted] balay/mumps-5.2.1
- [deleted] balay/test
- [deleted] balay/update-petsc4py-DIVERGED_TR_DELTA
- [deleted] balay/update-petsc4py-jul-2019
- [deleted] balay/update-petsc4py-rm-PETSC_USE_SCALAR_type-2
- [deleted] balay/update-solaris-mpich
- [deleted] barry/10-7-2019/fix-prefix-null-error-message
- [deleted] barry/10-7-2019/petscint-size-t
- [deleted] barry/13-7-2019/docs-update-installation-doe-windows
- [deleted] barry/13-7-2019/fix-gmaketest-depend
- [deleted] barry/13-7-2019/fix-mkl-version
- [deleted] barry/13-7-2019/warn-old-gnumake
- [deleted] barry/2-7-2019/add-info-on-doe-machines-to-installation
- [deleted] barry/2-7-2019/fix-colpack-install
- [deleted] barry/2019-07-13/small-windows-features
- [deleted] barry/2019-07-14/fix-stag-example
- [deleted] barry/2019-07-18/fix-use-socket
- [deleted] barry/2019-07-19/PetscKernel-macros-to-functions
- [deleted] barry/2019-07-21/fix-petscmallocvalidate-checkmumpshermetian
- [deleted] barry/2019-07-21/parallel-fblaslapack-f2blaslapack
- [deleted] barry/2019-07-21/scalapack-mumps-parallel-make
- [deleted] barry/2019-07-22/fix-sdotnrm-blas-test
- [deleted] barry/2019-07-25/dalcinl/feature-math
- [deleted] barry/2019-07-26/addmissing-pcgamgclassicalfortran
- [deleted] barry/2019-07-30/add-use-petscintcast-corrected
- [deleted] barry/2019-07-30/snesncg-updates
- [deleted] barry/2019-08-01/fix-matmpisbaijsetpreallocationcsr
- [deleted] barry/2019-08-04/add-petsc-prefix-hash-to-example
- [deleted] barry/2019-08-04/fix-maint-hdf5-include/maint
- [deleted] barry/2019-08-17/improve-openmp-handling
- [deleted] barry/2019-08-21/updates-pardiso
- [deleted] barry/2019-08-22/fix-fblaslapack-for-nag
- [deleted] barry/2019-09-01/feature-streams-openmp
- [deleted] barry/2019-09-01/robustify-version-check
- [deleted] barry/2019-09-15/fix-gsscant-getarray
- [deleted] barry/2019-09-20/remove-io-sequentialphase
- [deleted] barry/4-7-2019/src-code-fix-for-msys2/maint
- [deleted] barry/7-7-2019/clearer-config-messages
- [deleted] barry/9-7/2019/SNES_CONVERGED_TR_DELTA-Error
- [deleted] barry/check-quad-math
- [deleted] barry/cleanup-oldfortran-rules
- [deleted] barry/cleanup-petscconf-h
- [deleted] barry/feature-arch-hash
- [deleted] barry/feature-boundedint
- [deleted] barry/feature-pintocpu
- [deleted] barry/fix-fortran-cxx-libraries
- [deleted] barry/fix-matmffd
- [deleted] barry/fix-testharness-rm-dir-error
- [deleted] barry/fix-use-with-dynamic-ld
- [deleted] barry/newtontr-post-check
- [deleted] barry/no-batch-script
- [deleted] barry/petscoptionsint-help-message-new-value
- [deleted] barry/references-newtontr-cg
- [deleted] barry/rm-readwrite
- [deleted] barry/sanity-check-freshdownload
- [deleted] barry/update-openblas
- [deleted] barry/utilize-matdensegetarrayread
- [deleted] dalcinl/feature-math
- [deleted] denera/tao-linesearch-manual-pages
- [deleted] denera/tao-steplength-typo-fix
- [deleted] dmay/fix-MatPreallocator/maint
- [deleted] gropp/doc-fixes-1
- [deleted] hannah/gpu-computation-logging
- [deleted] hannah/gpu-gpu-logging
- [deleted] hannah/gpu-logging-WaitForGPU
- [deleted] hongzh/fix-random-adjoint-bug
- [deleted] hongzh/turn-on-avx512-kernels-by-default
- [deleted] hzhang/add-ksp-tutorials-ex6/master
- [deleted] hzhang/dmnetwork-vltogordering
- [deleted] hzhang/fix-matmissingdiag/maint
- [deleted] hzhang/opt-mumps-matmatsolve
- [deleted] hzhang/pdmnetwork-setup
- [deleted] jczhang/feature-better-quicksort-pivot
- [deleted] jczhang/feature-extend-vscat-example
- [deleted] jczhang/feature-sf-on-gpu
- [deleted] jczhang/fix-dm-originaldm/maint
- [deleted] jczhang/fix-matpreallocator-stash-bs
- [deleted] jczhang/fix-overlapped-sf
- [deleted] jczhang/fix-test-harness-empty-ouput-after-grep
- [deleted] jczhang/fix-ubuntu-openmpi-anysource
- [deleted] jczhang/fix-unused-variable
- [deleted] jczhang/sf-more-opts
- [deleted] jed/binary-io
- [deleted] jed/deprecate-dmgetdefaultsection
- [deleted] jed/examples-use-dmboundarytypes
- [deleted] jed/feature-plex-tensor-noninterpolated
- [deleted] jed/fix-DM-output-addresses
- [deleted] jed/fix-gpu-docs
- [deleted] jed/fix-med-types/maint
- [deleted] jed/fix-pkg-config/maint
- [deleted] jed/fix-type-type_name/maint
- [deleted] jed/gitlab-ci
- [deleted] jed/gmakefile-include-by-goals
- [deleted] jed/remove-TARGET_ARCH
- [deleted] jose/densecuda-warnings
- [deleted] jose/harness-requires-debug
- [deleted] jose/warning-glvis
- [deleted] karlrupp/aij-add-missing-settypes
- [deleted] karlrupp/change-gamg-reduction-logic-a-bit
- [deleted] karlrupp/fix-cuda-MatSeqAIJCUSPARSEGenerateTransposeForMult
- [deleted] karlrupp/fix-cuda-empty-procs
- [deleted] karlrupp/fix-cuda-vecset
- [deleted] karlrupp/fix-cusparse-transpose-numrows
- [deleted] karlrupp/fix-disable-inodes-for-gpus
- [deleted] karlrupp/remove-ancient-cuda-version-checks
- [deleted] knepley/comment-dmplexcreatespectralclosurepermu-1556140811897
- [deleted] knepley/externalhtml-edited-online-with-bitbucke-1556665077291
- [deleted] knepley/feature-benchmark-plotonly
- [deleted] knepley/feature-plex-hybrid-input
- [deleted] knepley/fix-med-inversion
- [deleted] knepley/fix-plex-distribute-overlap
- [deleted] pefarrell/pcksp-set-dm
- [deleted] pr1533/florianwechsung/fw/empty-patch-bug/master
- [deleted] pr1605/m_diehl/fortran-tests/master
- [deleted] pr1723/tappel/extend-mumps-parameters/master
- [deleted] pr1819/jkruzik/feature-pcdeflation/master
- [deleted] pr1835/al007/reset-prealloc-comm/master
- [deleted] pr1921/haplav/fix-plex-ex18-spacedim-1D/maint
- [deleted] psanan/dev-manual-petsc-extern-example-update
- [deleted] psanan/dmda-vtk-view-fieldnames
- [deleted] psanan/dmstag-periodic-one-rank
- [deleted] psanan/doc-dmstagcreatecompatibledmstag-manpage-typo-fix/maint
- [deleted] rmills/mat-kaij
- [deleted] stefano_zampini/GPU-matdensecuda
- [deleted] stefano_zampini/fix-cudadense-warnings
- [deleted] stefano_zampini/fix-partitioner
- [deleted] stefano_zampini/fix-plex
- [deleted] stefano_zampini/fix-plex-matis-bs
- [deleted] stefano_zampini/fix-wedge-s2t
- [deleted] stefano_zampini/sbaij-example
