[petsc-dev] git repo branches housekeeping
    Balay, Satish
    balay at mcs.anl.gov
    Tue Sep 26 20:43:10 CDT 2017
ref: https://lists.mcs.anl.gov/pipermail/petsc-dev/2016-April/019014.html
I've deleted all deveopment branches that are already merged into
maint (v3.8) from https://bitbucket.org/petsc/petsc
However if you wish to remove these branches from your clone - it has
to be done manually (in each clone).
To get this list of branches to delete - you can do:
git branch --merged v3.8 |egrep -v " (maint|master|next)" > branches_to_delete
After *verifying* the list is correct - and ok to delete - they can be
deleted with:
git branch -d `cat branches_to_delete`
And to sync the [deleted] remove branch list info - you can do:
git fetch -p
For more housekeeping - look at the remaining local and remote
branches and figure-out what to do. [perhaps some of them are
intermediate branches during rebase - or abandoned features that
should be deleted]. For my branches - I would do:
git branch
git branch -r |grep balay
Satish
reference for self:
$ git branch -r --merged v3.8 |egrep  -v origin/\(maint\|master\|next\) |sed -e s%origin/%:% >  remote_branches_to_delete
$ git push -u origin `cat remote_branches_to_delete`
To bitbucket.org:petsc/petsc.git
 - [deleted]               Fande-Kong/feature_snes_has_dm
 - [deleted]               Fande-Kong/gasm_check_setsubdomains
 - [deleted]               Fande_Kong/PetscOptionsGetUnusedOptions
 - [deleted]               balay/add-blas-dep-to-fftw/maint
 - [deleted]               balay/add-cxx-f-math-z-libs-deps
 - [deleted]               balay/add-fstack-protector
 - [deleted]               balay/add-ftn-PetscDataTypeGetSize
 - [deleted]               balay/add-matlab-test
 - [deleted]               balay/add-mvapich-version-check
 - [deleted]               balay/add-petsc4py-python
 - [deleted]               balay/add-prefix-test
 - [deleted]               balay/bugfix-klu-64bitindices/maint
 - [deleted]               balay/check-dep-download
 - [deleted]               balay/clang-Wcomma
 - [deleted]               balay/disable-msmpi-mpiio
 - [deleted]               balay/disable-ssh-hwloc-bydefault
 - [deleted]               balay/disable-visibility-for-static-build
 - [deleted]               balay/enable-download-zlib-static
 - [deleted]               balay/fix-MatGetRowIJ_SeqAIJ_Inode
 - [deleted]               balay/fix-PetscInt-scanf/maint
 - [deleted]               balay/fix-c89-func-test/maint
 - [deleted]               balay/fix-checkMKL
 - [deleted]               balay/fix-clang-va_start-warning
 - [deleted]               balay/fix-configure-lm-Ofast
 - [deleted]               balay/fix-ctable-hash
 - [deleted]               balay/fix-eigen-prefix
 - [deleted]               balay/fix-format-security/maint
 - [deleted]               balay/fix-isgnu-for-ccache
 - [deleted]               balay/fix-matlab-test
 - [deleted]               balay/fix-ml-suitesparse-single
 - [deleted]               balay/fix-mpi-ver-test/maint
 - [deleted]               balay/fix-mumps-intel17-openmpi/maint
 - [deleted]               balay/fix-pic-check-ubuntu1610/maint
 - [deleted]               balay/fix-quad-complex-from-cxx
 - [deleted]               balay/fix-redundant-decls-warnings-master
 - [deleted]               balay/fix-scalapack-pic/maint
 - [deleted]               balay/fix-superlu-nof
 - [deleted]               balay/fix-win32fe-tmp-obj-usage
 - [deleted]               balay/fix-with-cuda
 - [deleted]               balay/fix-xcode8-warning/maint
 - [deleted]               balay/gfortran-4.4-fixes
 - [deleted]               balay/hdf5-switch-zlib-to-odep
 - [deleted]               balay/improve-git-externalpackage-co-error-
message
 - [deleted]               balay/mkl-use-detected-mathlib/maint
 - [deleted]               balay/move_mpiinc_to_cudac_flags/maint
 - [deleted]               balay/mpiuni-namespace-fc
 - [deleted]               balay/osx-mkl/maint
 - [deleted]               balay/print-mpi.h-info/maint
 - [deleted]               balay/ptscotch-build-esmumps/maint
 - [deleted]               balay/split-mpiuni-f-def
 - [deleted]               balay/switch-pflotran-to-git-mirror
 - [deleted]               balay/sync-64bit-mpitype
 - [deleted]               balay/test
 - [deleted]               balay/test-with-mpich-errorcheck
 - [deleted]               balay/testharness-wPETSC_DIR
 - [deleted]               balay/to-maint-fix-cpardiso-mkl-detection
 - [deleted]               balay/update-MUMPS_5.0.2
 - [deleted]               balay/update-PETSC_ARCH-errorcheck/maint
 - [deleted]               balay/update-cmake-elemental-v0.87-squashed
 - [deleted]               balay/update-hdf5-netcdf-squashed
 - [deleted]               balay/update-hypre-v2.11.1/maint
 - [deleted]               balay/update-ml-v6.2-p4/maint
 - [deleted]               balay/update-mpich-3.3a2-squashed
 - [deleted]               balay/update-mumps-5.1.1
 - [deleted]               balay/update-pastix-5.2.3/maint
 - [deleted]               balay/update-pgi-test/maint
 - [deleted]               balay/update-ptscotch-6.0.4/maint
 - [deleted]               balay/update-sowing-1.1.25-p1
 - [deleted]               balay/update-sowing-enum
 - [deleted]               balay/update-strumpack-1.0.4
 - [deleted]               balay/update-xsdk-oct-2016
 - [deleted]               balay/update_superlu_and_dist/maint
 - [deleted]               balay/use-PetscInt64
 - [deleted]               balay/vs6-warning-fixes
 - [deleted]               balay/win-icl
 - [deleted]               balay/win32-dll
 - [deleted]               balay/with-fortran-bindings
 - [deleted]               barry-update-hypre-2.12.0
 - [deleted]               barry/Sander/fix-pcreset-fieldsplit
 - [deleted]               barry/add-MatSeqSBAIJGetArray
 - [deleted]               barry/add-bcgsl-test
 - [deleted]               barry/add-dmda-rotate-boundary-conditions-
example
 - [deleted]               barry/add-download-serial-mumps
 - [deleted]               barry/add-errorcheck-pcfieldsplitgetsubksp
 - [deleted]               barry/add-fortran-interfaces
 - [deleted]               barry/add-fortran-tsadaptsettype
 - [deleted]               barry/add-ghost-neumann
 - [deleted]               barry/add-intro-help
 - [deleted]               barry/add-isload-binary
 - [deleted]               barry/add-matfdcoloring-ghosted-example
 - [deleted]               barry/add-matgetrow-interface
 - [deleted]               barry/add-matshell-matgetdiagonalblock-
fortran
 - [deleted]               barry/add-missing-apis/maint
 - [deleted]               barry/add-missing-fixreturnchar/maint
 - [deleted]               barry/add-missing-test-case/maint
 - [deleted]               barry/add-openblas-download
 - [deleted]               barry/add-parms-test
 - [deleted]               barry/add-petsc-stdout-fortran
 - [deleted]               barry/add-real-object-support-petscbinaryio
 - [deleted]               barry/add-snes-divtol
 - [deleted]               barry/add-snes-dmda-periodic
 - [deleted]               barry/add-trilinos-support-without-download
 - [deleted]               barry/add-tsadapt-default/maint
 - [deleted]               barry/add-yaml-options-test
 - [deleted]               barry/allow-changing-normtype-pcside-
afterset
 - [deleted]               barry/allow-multiple-downloaddirnames
 - [deleted]               barry/cleanup-external-mat-solver-packages
 - [deleted]               barry/consistent-formating-ascii-solver-
viewers
 - [deleted]               barry/convert-clique-to-elemental
 - [deleted]               barry/custom-vecscatter-view-fortran
 - [deleted]               barry/do-not-test-random-mpicc-with-mpi-dir
 - [deleted]               barry/docs-petscversion
 - [deleted]               barry/error-matload-if-dense-format/maint
 - [deleted]               barry/errorcheck-fortran-
petscobjectviewfromoptions
 - [deleted]               barry/extend-pcmg-galerkin
 - [deleted]               barry/f2clibs-may-need-lquadmath
 - [deleted]               barry/feature-aij-subtypes
 - [deleted]               barry/feature-check-mpi-library-runtime
 - [deleted]               barry/feature-fortran-petscerror
 - [deleted]               barry/feature-matdenseplacearray
matfdcoloringgetperturbedcolumns-f90
 - [deleted]               barry/feature-petscgetversionnumber
 - [deleted]               barry/feature-simple-spectral
 - [deleted]               barry/feature-snes-force-iteration
 - [deleted]               barry/feature-ts-monitor-solution
 - [deleted]               barry/fix-chaco-from-trilinos
 - [deleted]               barry/fix-compilerflags-for-packages
 - [deleted]               barry/fix-const-matdiagonalscale
 - [deleted]               barry/fix-dead-variables
 - [deleted]               barry/fix-dmcreatematrix-dmda
 - [deleted]               barry/fix-dmdacreate
 - [deleted]               barry/fix-dmshellsetglobalvector
 - [deleted]               barry/fix-duplicate-help
 - [deleted]               barry/fix-dynamic_library_preload
 - [deleted]               barry/fix-fortran-imaginary-part
 - [deleted]               barry/fix-fortran-interfaces-matsetvalues
 - [deleted]               barry/fix-huge-flaw-in-ts
 - [deleted]               barry/fix-ignore-returns
 - [deleted]               barry/fix-kspnormsupporttablereset
 - [deleted]               barry/fix-kspnormtypes
 - [deleted]               barry/fix-log_view
 - [deleted]               barry/fix-matmffd-type-fortran/maint
 - [deleted]               barry/fix-matmpixxxsetpreallocation-
reentrant
 - [deleted]               barry/fix-matreuse
 - [deleted]               barry/fix-multiple-identical-monitors/maint
 - [deleted]               barry/fix-nonnorm-convergencetest
 - [deleted]               barry/fix-osx-static-libraries
 - [deleted]               barry/fix-package-precision-dependency
 - [deleted]               barry/fix-pcmgsetcyclesonlevel
petscobjectcopyfortranfunctionpointers
 - [deleted]               barry/fix-petscobjectsetoptionsprefix/maint
 - [deleted]               barry/fix-seterrq
 - [deleted]               barry/fix-snes-qn-powell/maint
 - [deleted]               barry/fix-some-clang-warnings
 - [deleted]               barry/fix-source-clang
 - [deleted]               barry/fix-successful-numerical-
factorization-after-failure/maint
factorization-after-failure/master
 - [deleted]               barry/fix-testex182/maint
 - [deleted]               barry/fix-tfs
 - [deleted]               barry/fix-tscomputerhsjacobianconstant/maint
 - [deleted]               barry/fix-umfpack-empty-matrix
 - [deleted]               barry/fix-use-objectid-not-object-for-
comparison-in-ts
 - [deleted]               barry/fix-vecaypx-petschecksametypeandcomm
 - [deleted]               barry/fix-xml-logging
 - [deleted]               barry/fix/even-huger-flaw-in-ts
 - [deleted]               barry/forbid-spaces-in-petscdir-prefix
 - [deleted]               barry/fortran-update
 - [deleted]               barry/get-factor-failure-information-from-
mat
 - [deleted]               barry/half-precision
 - [deleted]               barry/housekeeping-1
 - [deleted]               barry/housekeeping-2
 - [deleted]               barry/improve-fortran-callback-error-
checking
 - [deleted]               barry/improve-gcov
 - [deleted]               barry/improve-mathasoperation
 - [deleted]               barry/improve-matnullspace-usage
 - [deleted]               barry/improve-pcasm-islocal
 - [deleted]               barry/improve-tao-test-gradient
 - [deleted]               barry/improve-ts-trajectory-viz
 - [deleted]               barry/install-examples
 - [deleted]               barry/make-functions-static
 - [deleted]               barry/make-test-checks-external-packages
 - [deleted]               barry/metis-gkrand
 - [deleted]               barry/minor-cleanup
 - [deleted]               barry/more-fortran-updates
 - [deleted]               barry/namespace-events
 - [deleted]               barry/pcmgsetsmoothupdown-if-no-change
 - [deleted]               barry/remove-funct
 - [deleted]               barry/remove-papi
 - [deleted]               barry/secant-update-infinity
 - [deleted]               barry/tellmycell
 - [deleted]               barry/tests-ksps
 - [deleted]               barry/ts-error-explicit-method-ifunction
 - [deleted]               barry/ts-view-tolerances
 - [deleted]               barry/tsadapt-one-line-monitor
 - [deleted]               barry/update-blaslapack-support-download-
batch
 - [deleted]               barry/update-petscfileretrieve
 - [deleted]               barry/update-ssl-to-1-1
 - [deleted]               barry/update-trilinos-build
 - [deleted]               barry/use-fortran-kind-consistently
 - [deleted]               barry/vecscattercreatetozero-fortran-null
 - [deleted]               blaise/exodus-update-git
 - [deleted]               dalcinl/ts-monitor-lg-timestep-log
 - [deleted]               damalbel/dmnetwork_dist
 - [deleted]               damalbel/dmnetwork_nest_indexing
 - [deleted]               damalbel/dmnetworkex1
 - [deleted]               damalbel/dmnetworkex1_local
 - [deleted]               deleeke/feature-configure-googletest
 - [deleted]               dmaldona/dmnetwork_ex2
 - [deleted]               dmay/developerlistupdate
 - [deleted]               dmay/dmswarm-fixes
 - [deleted]               dmay/dmswarm-remove-binary-readwrite
 - [deleted]               dmay/swarm-pic-tools
 - [deleted]               dmay/swarm-pic-tools-v3.8
 - [deleted]               dmay/telescope-nullspace-fix
 - [deleted]               dmay/test_matzerorows
 - [deleted]               elbueler/snesvi-ex9-simplification
 - [deleted]               emil/fix-glee-man-pages
 - [deleted]               emil/fix-ts-ex12
 - [deleted]               emil/rename-gl-to-glle
 - [deleted]               emil/ts-glee
 - [deleted]               hongzh/adjoint-parallel
 - [deleted]               hongzh/fix-tao-draw-monitor
 - [deleted]               hongzh/fix-tstraj
 - [deleted]               hongzh/ts-direct-sa
 - [deleted]               hzhang/DMNetworkAddComp
 - [deleted]               hzhang/ElementalHerk
 - [deleted]               hzhang/advection-example
 - [deleted]               hzhang/bugfix-RedundantMat/master
 - [deleted]               hzhang/bugfix-matdestroysubmats
 - [deleted]               hzhang/deprecate-getsubmat
 - [deleted]               hzhang/dmnetwork-rename
 - [deleted]               hzhang/dmnetwork-spJacobian3
 - [deleted]               hzhang/dmnetwork-vecview
 - [deleted]               hzhang/dmnetwork-vecview-nonascii
 - [deleted]               hzhang/fix-Matredundant-BAIJ
 - [deleted]               hzhang/fix-blockedIS-submat
 - [deleted]               hzhang/fix-dmi-blocksize
 - [deleted]               hzhang/fix-elementalSetOption
 - [deleted]               hzhang/fix-getsubmats-reuse
 - [deleted]               hzhang/fix-ilu0-baij
 - [deleted]               hzhang/fix-mat-ex72
 - [deleted]               hzhang/fix-matcreate-null-a
 - [deleted]               hzhang/fix-matduplicate_mpiaij_xxx
 - [deleted]               hzhang/fix-matgetfactor-err
 - [deleted]               hzhang/fix-matgetsubmat_sbaij
 - [deleted]               hzhang/fix-matgetsubmatrices-mpiaij
 - [deleted]               hzhang/fix-matmatmatmult
 - [deleted]               hzhang/fix-nonscalable-ctable-use
 - [deleted]               hzhang/fix-pc-PBJacobi-flops
 - [deleted]               hzhang/fix-pcfailedreason
 - [deleted]               hzhang/fix-ptap-seqaij
 - [deleted]               hzhang/fix-superlu_dist-reuse-factornumeric
 - [deleted]               hzhang/fix-superlu_dist-reuse-factornumeric1
 - [deleted]               hzhang/fix_matview_mpisbaij
 - [deleted]               hzhang/mat-help/master
 - [deleted]               hzhang/mat-structureonly
 - [deleted]               hzhang/matmatops_mpiaij4np1
 - [deleted]               hzhang/matptap-info
 - [deleted]               hzhang/matptap-scalable
 - [deleted]               hzhang/matseqbaij_bs11
 - [deleted]               hzhang/mkl_pardiso_matgetinertia
 - [deleted]               hzhang/mpirart
 - [deleted]               hzhang/opt-choleskyfactornumeric
 - [deleted]               hzhang/opt-dmnetwork
 - [deleted]               hzhang/opt-dmnetwork-ex1
 - [deleted]               hzhang/opt-matfdcoloringsetup
 - [deleted]               hzhang/opt-matgetsubmatrices-mpiaij
 - [deleted]               hzhang/opt-matgetsubmatrices-mpibaij
 - [deleted]               hzhang/opt-matgetsubmatrices-rebased-v2
 - [deleted]               hzhang/opt-matmatmult-nonscalable
 - [deleted]               hzhang/opt_scalable_MatCreateSubMatrix
 - [deleted]               hzhang/rename_matgetsubmats
 - [deleted]               hzhang/reorg-matdestroysubmats
 - [deleted]               hzhang/scalable_MatCreateSubMatrix
 - [deleted]               hzhang/superlu_dist-getdiaU
 - [deleted]               hzhang/ts-ex9busdmnetwork
 - [deleted]               hzhang/vec-ex28fix
 - [deleted]               jed/Wint-in-bool-context
 - [deleted]               jed/cleanup
 - [deleted]               jed/cleanup-report-tests
 - [deleted]               jed/config-mpi-hashline
 - [deleted]               jed/dmda-mat-setfromoptions
 - [deleted]               jed/fix-dm-dt-test-output-zero
 - [deleted]               jed/fix-dmda-ex51
 - [deleted]               jed/fix-dmdagetcellpoint-bounds-check
 - [deleted]               jed/fix-fpic-shared-clang
 - [deleted]               jed/fix-matcomposite-ftn-auto
 - [deleted]               jed/matgetrowsum-ones
 - [deleted]               jed/matisrestorelocalmat
 - [deleted]               jed/mpi-semver
 - [deleted]               jed/pkgconfig
 - [deleted]               jed/portable-restrict
 - [deleted]               jed/sf-shared-uni
 - [deleted]               jed/snes-ex5-mms-dedup
 - [deleted]               jose/aijcusparse-fix
 - [deleted]               jose/check-typename
 - [deleted]               jose/cusparse-sethandle
 - [deleted]               jose/fcallback
 - [deleted]               jose/fix-compile-cxx-cuda
 - [deleted]               jose/fix-cusparse-flag
 - [deleted]               jose/maint/tabs-print-class
 - [deleted]               jose/matlrc
 - [deleted]               jose/memory-leak-c89
 - [deleted]               jose/test-makefile
 - [deleted]               jose/veccuda-tests
 - [deleted]               jose/veccuda-witharray
 - [deleted]               jose/vecplacearray-gpu
 - [deleted]               jose/warning-plexcreate
 - [deleted]               karlrupp/doc-performance-chapter
 - [deleted]               karlrupp/feature-branches-summary
 - [deleted]               karlrupp/feature-viennacl-hybrid
preconditioners/master
 - [deleted]               karlrupp/fix-MatDuplicate-GPU
 - [deleted]               karlrupp/update-elemental
 - [deleted]               knepley/feature-adapt-interface
 - [deleted]               knepley/feature-bc-values-general
 - [deleted]               knepley/feature-boost-headers-only
 - [deleted]               knepley/feature-configure-eigen-pragmatic
 - [deleted]               knepley/feature-configure-ios-android
 - [deleted]               knepley/feature-convergence-estimator
 - [deleted]               knepley/feature-dm-bc-components
 - [deleted]               knepley/feature-dm-point-location-failure
 - [deleted]               knepley/feature-ex11-simplex
 - [deleted]               knepley/feature-fe-dual-apply
 - [deleted]               knepley/feature-fe-kernel-scalars
 - [deleted]               knepley/feature-fortran-compose
 - [deleted]               knepley/feature-mantle-example
 - [deleted]               knepley/feature-matis-example
 - [deleted]               knepley/feature-parallel-mesh-load
 - [deleted]               knepley/feature-partition-random
 - [deleted]               knepley/feature-plex-3d-sem-order
 - [deleted]               knepley/feature-plex-bdfunc
 - [deleted]               knepley/feature-plex-boundary-values
 - [deleted]               knepley/feature-plex-closure-reorder
 - [deleted]               knepley/feature-plex-ex-advection
 - [deleted]               knepley/feature-plex-gmsh-nodes
 - [deleted]               knepley/feature-plex-interpolation-perf
 - [deleted]               knepley/feature-plex-interpolation-test
 - [deleted]               knepley/feature-plex-particle-example
 - [deleted]               knepley/feature-plex-ply
 - [deleted]               knepley/feature-plex-pragmatic-parallel
 - [deleted]               knepley/feature-plex-project-submesh
 - [deleted]               knepley/feature-plex-projections
 - [deleted]               knepley/feature-plex-replicate
 - [deleted]               knepley/feature-plex-sphere-mesh
 - [deleted]               knepley/feature-plex-tests-new
 - [deleted]               knepley/feature-plex-torus
 - [deleted]               knepley/feature-plex-ts-examples
 - [deleted]               knepley/feature-plex-wedge
 - [deleted]               knepley/feature-realloc
 - [deleted]               knepley/feature-snes-stokes-test
 - [deleted]               knepley/feature-ts-mass-matrix
 - [deleted]               knepley/feature-xdmf-particles
 - [deleted]               knepley/fix-configure-blas-missing
 - [deleted]               knepley/fix-configure-dep-petsc
 - [deleted]               knepley/fix-configure-error-logging
 - [deleted]               knepley/fix-configure-petsc-dep
 - [deleted]               knepley/fix-configure-pragmatic
 - [deleted]               knepley/fix-dm-blocksize
 - [deleted]               knepley/fix-dm-embed-dim
 - [deleted]               knepley/fix-dm-interpolation-parallel
 - [deleted]               knepley/fix-dm-l2g
 - [deleted]               knepley/fix-dm-label-name-fortran
 - [deleted]               knepley/fix-dm-ltog-bs
 - [deleted]               knepley/fix-dm-outputdm
 - [deleted]               knepley/fix-dmlabel-fortran
 - [deleted]               knepley/fix-docs-headers
 - [deleted]               knepley/fix-ex-types
 - [deleted]               knepley/fix-ex18-types
 - [deleted]               knepley/fix-fe-default
 - [deleted]               knepley/fix-fe-fortran
 - [deleted]               knepley/fix-logging-reductions
 - [deleted]               knepley/fix-petscdir-check
 - [deleted]               knepley/fix-petscfe-kernels-ts
 - [deleted]               knepley/fix-plex-bs
 - [deleted]               knepley/fix-plex-cgns
 - [deleted]               knepley/fix-plex-coord-dim
 - [deleted]               knepley/fix-plex-docs
 - [deleted]               knepley/fix-plex-example-logging
 - [deleted]               knepley/fix-plex-examples-cleanup
 - [deleted]               knepley/fix-plex-gmsh-parse
 - [deleted]               knepley/fix-plex-interp-parallel
 - [deleted]               knepley/fix-plex-interp-quad
 - [deleted]               knepley/fix-plex-l2g
 - [deleted]               knepley/fix-plex-link
 - [deleted]               knepley/fix-plex-mat-bs
 - [deleted]               knepley/fix-plex-mat-dm
 - [deleted]               knepley/fix-plex-mf-prec
 - [deleted]               knepley/fix-plex-namespace
 - [deleted]               knepley/fix-plex-order
 - [deleted]               knepley/fix-plex-output
 - [deleted]               knepley/fix-plex-parallel-load
 - [deleted]               knepley/fix-plex-pmat
 - [deleted]               knepley/fix-plex-regression
 - [deleted]               knepley/fix-plex-spectral-order
 - [deleted]               knepley/fix-plex-static
 - [deleted]               knepley/fix-section-fortran-null
 - [deleted]               knepley/fix-snes-ex69-prec
 - [deleted]               knepley/fix-submesh-orientation
 - [deleted]               knepley/fix-tao-ex1
 - [deleted]               knepley/fix-test-requirements
 - [deleted]               knepley/fix-vec-visibility
 - [deleted]               knepley/test-process-arg
 - [deleted]               mark/gamg-aijtest
 - [deleted]               mark/gamg-doc
 - [deleted]               mark/gamg-fix
 - [deleted]               mark/gamg-snesex56
 - [deleted]               mark/mat-fix-scaleable
 - [deleted]               mark/snes-ex56
 - [deleted]               mark/snes-ex56-b
 - [deleted]               mark/snes-ex56-c
 - [deleted]               mlange/feature-plex-med
 - [deleted]               pefarrell/dmshell-asm-clean
 - [deleted]               pefarrell/fas-use-dm-create-restriction
 - [deleted]               pefarrell/mat-galerkin
 - [deleted]               pefarrell/nasm-fixes-clean
 - [deleted]               pr464/pieter_ghysels/pghysels/strumpack-
interface-rebased/master
 - [deleted]               pr473/alexfikl/alexfikl/fortran-
visibility/maint
 - [deleted]               pr476/psanan/psanan/pc-telescope-subcomm-
type/master
 - [deleted]               pr478/knepley/feature-dmplex-adapt/master
 - [deleted]               pr480/alexfikl/alexfikl/fortran-
viewer/master
 - [deleted]               pr495/mapdes/snes-compute-final-residual-
flag/master
 - [deleted]               pr500/knepley/fix-plex-gmsh/master
 - [deleted]               pr508/psanan/psanan/pc-telescope-
nearnullspace/master
 - [deleted]               pr511/vlc1/fix-fortran-dmda-optional-
argument/master
[deleted]               pr518/kooky089/jacht/PetscInitializeNoArguments
-fortran/master
 - [deleted]               pr520/psanan/psanan/vtk-viewer-leak-
fix/master
 - [deleted]               pr521/vlc1/fortran-
MatNullSpaceGetVecs/master
 - [deleted]               pr523/alexfikl/alexfikl/dmcomposite-local-
vectors/master
 - [deleted]               pr527/alexfikl/alexfikl/matshell-fortran-
operations/master
[deleted]               pr529/sanderarens/plex_gmsh_vertex_sets/master
 - [deleted]               pr530/psanan/mat-viennacl-conversions/master
 - [deleted]               pr540/dmeiser/analyze-examples/master
 - [deleted]               pr543/alexfikl/alexfikl/matnest-
transpose/master
 - [deleted]               pr552/vlc1/vlc1/dmcomposite/master
 - [deleted]               pr555/alexfikl/alexfikl/matshell-copy/master
 - [deleted]               pr566/knepley/plex_bd_aux_field/master
 - [deleted]               pr575/knepley/fix-labels-coordinatedm/master
 - [deleted]               pr605/mapdes/runtime-
noviewfromoptions/master
 - [deleted]               pr614/sanderarens/fix-plex-hdf5/master
 - [deleted]               pr628/mapdes/scalable-isgtol/master
 - [deleted]               pr630/alexfikl/alexfikl/fortran-
missing/master
 - [deleted]               pr643/sanderarens/fix-
dmplexlabelcomplete/master
 - [deleted]               pr644/vijaysm/update-dmmoab-5/master
 - [deleted]               pr646/scools/scools/pipebcgs/master
 - [deleted]               pr647/adam_qc/high-order-ams-ads/master
 - [deleted]               pr659/knepley/dmshell-asm-clean/master
 - [deleted]               pr687/Joel-Venzke/fix-hdf5-chunck-
size/master
 - [deleted]               pr690/mapdes/feature-plex-user-
adjacency/master
 - [deleted]               pr698/scools/scools/pipecgrr-v2/master
 - [deleted]               pr718/hy144328/fix-mumps-
configuration/master
 - [deleted]               pr741/psanan/psanan/quad-binary-fixes/maint
 - [deleted]               pr742/francesco_ballarin/mat-missing-
diagonal-elemental/master
 - [deleted]               psanan/dm-ex7-fix
 - [deleted]               psanan/fix-KSPPIPEFGMRES-warning/maint
 - [deleted]               psanan/manual-fix
 - [deleted]               psanan/typo-matfindzerodiagonals-man-page
 - [deleted]               psanan/typo-parallelism-2017-01
 - [deleted]               psanan/typo-publications-2016-11
 - [deleted]               psanan/usingfortran-typo-fixes
 - [deleted]               rmills/add-aijmkl
 - [deleted]               scott/feature-gmakefile-help
 - [deleted]               scott/test-datafiles-fix
 - [deleted]               scott/test-harness-altfiles
 - [deleted]               scott/test-harness-comments
 - [deleted]               scott/test-harness-f90freeform
 - [deleted]               scott/test-harness-forloopfix
 - [deleted]               scott/test-harness-options
 - [deleted]               scott/test-harness-search2
 - [deleted]               scott/test-harness-skipdiff
 - [deleted]               scott/test-harness-valgrind-v2
 - [deleted]               scott/testharness-update1
 - [deleted]               shri/dmnetwork-add-vertexweights-partition
 - [deleted]               shri/fixes-for-step-restart
 - [deleted]               shri/ts-post-evaluate
 - [deleted]               stefano_zampini/allow-late-matsetblocksizes
 - [deleted]               stefano_zampini/allow-unassembled-
computeijacobian
 - [deleted]               stefano_zampini/dmplex-matis-support-2
 - [deleted]               stefano_zampini/enhancements-fetidp-
saddlepoint
 - [deleted]               stefano_zampini/feature-allow-bddc-
monolithic
monolithic-2
 - [deleted]               stefano_zampini/feature-allow-dg-dolfin
mumpsparallelschur
 - [deleted]               stefano_zampini/feature-convert-matnest-
matis
 - [deleted]               stefano_zampini/feature-convert-nest-aij-
fast
 - [deleted]               stefano_zampini/feature-fetidp-class
 - [deleted]               stefano_zampini/feature-fetidp-ex69
 - [deleted]               stefano_zampini/feature-getmat-mattranspose
 - [deleted]               stefano_zampini/feature-glvis-viewer
 - [deleted]               stefano_zampini/feature-glvis-viewer-
fixdmdependency2
 - [deleted]               stefano_zampini/feature-gmsh-periodic
 - [deleted]               stefano_zampini/feature-hypre-block-interp
improvematfactorschur
 - [deleted]               stefano_zampini/feature-kspguess-class
 - [deleted]               stefano_zampini/feature-mathypre
 - [deleted]               stefano_zampini/feature-matis-missingops
 - [deleted]               stefano_zampini/feature-pcbddc-saddlepoint
 - [deleted]               stefano_zampini/feature-plex-simplex-to-
tensor
 - [deleted]               stefano_zampini/feature-sparserhs
 - [deleted]               stefano_zampini/feature-usehyprematmatops
 - [deleted]               stefano_zampini/fix-analyzer
 - [deleted]               stefano_zampini/fix-bddcnullspace
 - [deleted]               stefano_zampini/fix-bddcschurs
 - [deleted]               stefano_zampini/fix-bddcschurs-
wrongreusematrix
 - [deleted]               stefano_zampini/fix-chebyshev-rhslocked
 - [deleted]               stefano_zampini/fix-dmwswarm-includes-
andothers
 - [deleted]               stefano_zampini/fix-ex59-output
 - [deleted]               stefano_zampini/fix-getri-error-mkl
 - [deleted]               stefano_zampini/fix-glvis-staticanalysis
 - [deleted]               stefano_zampini/fix-gmsh-inverted-triangles
 - [deleted]               stefano_zampini/fix-gmsh-noinvtri
 - [deleted]               stefano_zampini/fix-improper-use-of-diag
 - [deleted]               stefano_zampini/fix-matcreatefromparcsr-
emptyrowscols
 - [deleted]               stefano_zampini/fix-matgetrowij
 - [deleted]               stefano_zampini/fix-mathypre-example
 - [deleted]               stefano_zampini/fix-mathypre-notpreallocated
 - [deleted]               stefano_zampini/fix-matis
 - [deleted]               stefano_zampini/fix-matis-addlocalprealloc
 - [deleted]               stefano_zampini/fix-matis-missing-
setuplayout
 - [deleted]               stefano_zampini/fix-matshift
 - [deleted]               stefano_zampini/fix-mattranspose-is
 - [deleted]               stefano_zampini/fix-matzerorowsaij-bug
 - [deleted]               stefano_zampini/fix-missing-chkerrv-symbol
 - [deleted]               stefano_zampini/fix-p4estview-glvis
 - [deleted]               stefano_zampini/fix-periodic-glvis
 - [deleted]               stefano_zampini/fix-pod-zeroenergy
 - [deleted]               stefano_zampini/fix-rectangular-dense-
matisgetmpixaij
 - [deleted]               stefano_zampini/fix-set-but-not-used
 - [deleted]               stefano_zampini/fix-zerosize-
matcreateseqaijwitharrays
 - [deleted]               stefano_zampini/hypre-ams-zerointerior-
feature
 - [deleted]               stefano_zampini/matis-getinfo
 - [deleted]               stefano_zampini/smallfix-glvis
 - [deleted]               stefano_zampini/smallfix-scaling
 - [deleted]               stefano_zampini/smallfixes-matis
 - [deleted]               test-harness-replacefix
 - [deleted]               tisaac/builder-fix-empty-targets
 - [deleted]               tisaac/dm-boundary-in-ds
 - [deleted]               tisaac/dm-feature-adapt-label
 - [deleted]               tisaac/dm-label-use-is
 - [deleted]               tisaac/dmforest-uncrustify
 - [deleted]               tisaac/dmlabel-fix-clear-bt
 - [deleted]               tisaac/dmlabel-fix-get-stratum-bounds
 - [deleted]               tisaac/dmp4est-feature-mapped-coordinates
 - [deleted]               tisaac/dmp4est-fix-overlap
 - [deleted]               tisaac/dmp4est-fix-set-point-sf
 - [deleted]               tisaac/dmp4est-fix-transfer-point
 - [deleted]               tisaac/dmp4est-set-periodic-domain
 - [deleted]               tisaac/dmp4est-silence-unused
 - [deleted]               tisaac/dmplex-feature-quadrature-in-geom
 - [deleted]               tisaac/dmplex-feature-real-to-ref
 - [deleted]               tisaac/dmplex-fix-hex-box-periodicity
 - [deleted]               tisaac/dmplex-fix-nonaffine-geom
 - [deleted]               tisaac/dmplex-localize-targeted
 - [deleted]               tisaac/dmplex-tree-constraints-aggregate
 - [deleted]               tisaac/dt-feature-avoid-tgamma
 - [deleted]               tisaac/dualspace-feature-symmetry
 - [deleted]               tisaac/dualspace-lagrange-feature-
lexicographic
 - [deleted]               tisaac/feature-ex11-conservative-example
 - [deleted]               tisaac/feature-fe-dual-apply
 - [deleted]               tisaac/feature-fortran-compose
 - [deleted]               tisaac/feature-gentest-varsubst
 - [deleted]               tisaac/feature-mantle-example
 - [deleted]               tisaac/feature-plex-deterministic-viewing
 - [deleted]               tisaac/feature-plex-tests-new
 - [deleted]               tisaac/feature-test-force
 - [deleted]               tisaac/feature-vec-tagger
 - [deleted]               tisaac/fix-cmplx
 - [deleted]               tisaac/fix-complex-tagger
 - [deleted]               tisaac/fix-cxx-rules
 - [deleted]               tisaac/fix-dm-tests
 - [deleted]               tisaac/fix-ex3-coords
 - [deleted]               tisaac/fix-hdf5-complex
 - [deleted]               tisaac/fix-ksp-cheby-supported-norm
 - [deleted]               tisaac/fix-med-hdf5
 - [deleted]               tisaac/fix-petsccmplx
 - [deleted]               tisaac/fix-pipeline-tests
 - [deleted]               tisaac/fix-plex-tree-transfer-inject
 - [deleted]               tisaac/fix-snes-tests-ex2_8
 - [deleted]               tisaac/is-fix-min-max
 - [deleted]               tisaac/partition-fix-doc
 - [deleted]               tisaac/petscfe-fix-default-quadrature
 - [deleted]               tisaac/petscfe-matching-quadrature-order
 - [deleted]               tisaac/plex-fix-copy-coordinates
 - [deleted]               tisaac/plex-fix-ex6-printf
 - [deleted]               tisaac/plex-fix-partition-overlap
 - [deleted]               tisaac/plex-tree-cleanup-anchor-matrix
 - [deleted]               tisaac/plex-tree-transfer-vec-doc
 - [deleted]               tisaac/random123
 - [deleted]               tisaac/sys-fix-realloc
 - [deleted]               tisaac/thplex-makefile-examples
 - [deleted]               tisaac/ts-ex11-amr
 - [deleted]               tisaac/update-p4est
 - [deleted]               tmunson/docs-fix-developer-doc
 - [deleted]               tmunson/kspcg-fix-trust-region-functions
 - [deleted]               tmunson/tao-bqpip-fix-code-and-documentationu
