[petsc-dev] error with karlrupp/fix-cuda-streams
Balay, Satish
balay at mcs.anl.gov
Wed Sep 25 17:23:21 CDT 2019
> 18:16 (cb53a04...) ~/petsc-karl$
So this is the commit I recommended you test against - and that's what
you have got now. Please go ahead and test.
[note: the branch is rebased - so 'git pull' won't work -(as you can
see from the "(forced update)" message - and '<>' status from git
prompt on balay/fix-mpiexec-shell-escape). So perhaps its easier to
deal with in detached mode - which makes this obvious]
Satish
On Wed, 25 Sep 2019, Mark Adams via petsc-dev wrote:
> I will test this now but ....
> 17:52 balay/fix-mpiexec-shell-escape= ~/petsc-karl$ git fetch
> remote: Enumerating objects: 119, done.
> remote: Counting objects: 100% (119/119), done.
> remote: Compressing objects: 100% (91/91), done.
> remote: Total 119 (delta 49), reused 74 (delta 28)
> Receiving objects: 100% (119/119), 132.88 KiB | 0 bytes/s, done.
> Resolving deltas: 100% (49/49), completed with 1 local objects.
> >From https://gitlab.com/petsc/petsc
> + b5e99a5...cb53a04 balay/fix-mpiexec-shell-escape ->
> origin/balay/fix-mpiexec-shell-escape (forced update)
> + ffdc635...7eeb5f9 jczhang/feature-sf-on-gpu ->
> origin/jczhang/feature-sf-on-gpu (forced update)
> cb9de97..f9ff08a jolivet/fix-error-col-row ->
> origin/jolivet/fix-error-col-row
> 40ea605..de5ad60 oanam/jacobf/cell-to-ref-mapping ->
> origin/oanam/jacobf/cell-to-ref-mapping
> + ecac953...9fb579e stefanozampini/hypre-cuda-rebased ->
> origin/stefanozampini/hypre-cuda-rebased (forced update)
> 18:16 balay/fix-mpiexec-shell-escape<> ~/petsc-karl$ git checkout
> Note: checking out 'origin/balay/fix-mpiexec-shell-escape'.
> You are in 'detached HEAD' state. You can look around, make experimental
> changes and commit them, and you can discard any commits you make in this
> state without impacting any branches by performing another checkout.
> If you want to create a new branch to retain commits you create, you may
> do so (now or later) by using -b with the checkout command again. Example:
> git checkout -b new_branch_name
> HEAD is now at cb53a04... mpiexec: fix shell escape of path-to-mpiexec only
> when using autodected-path. Also spectrum MPI uses OMPI_MAJOR_VERSION etc -
> so check if mpiexec supports --oversubscribe - before using it.
> On Wed, Sep 25, 2019 at 5:58 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> > Defined "VERSION_GIT" to ""v3.11.3-2242-gb5e99a5""
> > This is not the latest state - It should be:
> > commit cb53a042369fb946804f53931a88b58e10588da1 (HEAD ->
> > balay/fix-mpiexec-shell-escape, origin/balay/fix-mpiexec-shell-escape)
> > Try:
> > git fetch
> > git checkout origin/balay/fix-mpiexec-shell-escape
> > Satish
> > > On Wed, Sep 25, 2019 at 4:57 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> > > > > I did test this and sent the log (error).
> > > > Mark,
> > > > I made more changes - can you retry again - and resend log.
> > > > Satish
