[petsc-dev] error with karlrupp/fix-cuda-streams
Mark Adams mfadams at lbl.gov
Wed Sep 25 17:18:01 CDT 2019
I will test this now but ....
17:52 balay/fix-mpiexec-shell-escape= ~/petsc-karl$ git fetch
remote: Enumerating objects: 119, done.
remote: Counting objects: 100% (119/119), done.
remote: Compressing objects: 100% (91/91), done.
remote: Total 119 (delta 49), reused 74 (delta 28)
Receiving objects: 100% (119/119), 132.88 KiB | 0 bytes/s, done.
Resolving deltas: 100% (49/49), completed with 1 local objects.
>From https://gitlab.com/petsc/petsc
 + b5e99a5...cb53a04 balay/fix-mpiexec-shell-escape ->
origin/balay/fix-mpiexec-shell-escape  (forced update)
 + ffdc635...7eeb5f9 jczhang/feature-sf-on-gpu ->
origin/jczhang/feature-sf-on-gpu  (forced update)
   cb9de97..f9ff08a  jolivet/fix-error-col-row ->
origin/jolivet/fix-error-col-row
   40ea605..de5ad60  oanam/jacobf/cell-to-ref-mapping ->
origin/oanam/jacobf/cell-to-ref-mapping
 + ecac953...9fb579e stefanozampini/hypre-cuda-rebased ->
origin/stefanozampini/hypre-cuda-rebased  (forced update)
18:16 balay/fix-mpiexec-shell-escape<> ~/petsc-karl$ git checkout
Note: checking out 'origin/balay/fix-mpiexec-shell-escape'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
  git checkout -b new_branch_name
HEAD is now at cb53a04... mpiexec: fix shell escape of path-to-mpiexec only
when using autodected-path. Also spectrum MPI uses OMPI_MAJOR_VERSION etc -
so check if mpiexec supports --oversubscribe - before using it.
18:16 (cb53a04...) ~/petsc-karl$
On Wed, Sep 25, 2019 at 5:58 PM Balay, Satish <balay at mcs.anl.gov> wrote:
>             Defined "VERSION_GIT" to ""v3.11.3-2242-gb5e99a5""
> This is not the latest state - It should be:
> commit cb53a042369fb946804f53931a88b58e10588da1 (HEAD ->
> balay/fix-mpiexec-shell-escape, origin/balay/fix-mpiexec-shell-escape)
> Try:
> git fetch
> git checkout origin/balay/fix-mpiexec-shell-escape
> Satish
> On Wed, 25 Sep 2019, Mark Adams via petsc-dev wrote:
> > On Wed, Sep 25, 2019 at 4:57 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> > > > I did test this and sent the log (error).
> > > Mark,
> > > I made more changes - can you retry again - and resend log.
> > > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190925/43805454/attachment.html>
