[petsc-dev] error with karlrupp/fix-cuda-streams
Balay, Satish
balay at mcs.anl.gov
Wed Sep 25 13:19:20 CDT 2019
On Wed, 25 Sep 2019, Mark Adams via petsc-dev wrote:
> On Wed, Sep 25, 2019 at 12:44 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> > Can you retry with updated balay/fix-mpiexec-shell-escape branch?
> > current mpiexec interface/code in petsc is messy.
> > Its primarily needed for the test suite. But then - you can't easily
> > run the test suite on machines like summit.
> > Also - it assumes mpiexec provided supports '-n 1'. However if one
> > provides non-standard mpiexec such as --with-mpiexec="jsrun -g 1" -
> > what is the appropriate thing here?
> jsrun does take -n. It just has other args. I am trying to check if it
> requires other args. I thought it did but let me check.
https://www.olcf.ornl.gov/for-users/system-user-guides/summitdev-quickstart-guide/
-n --nrs Number of resource sets
Beta2 Change (October 17):
-n was be replaced by -nnodes
So its not the same functionality as 'mpiexec -n'
Either way - please try the above branch
Satish
> > And then configure needs to run some binaries for some checks - here
> > perhaps '-n 1' doesn't matter. [MPICH defaults to 1, OpenMPI defaults
> > to ncore]. So perhaps mpiexec is required for this purpose on summit?
> > And then there is this code to escape spaces in path - for
> > windows. [but we have to make sure this is not in code-path for user
> > specified --with-mpiexec="jsrun -g 1"
> > Satish
> > > No luck,
> > > On Wed, Sep 25, 2019 at 10:01 AM Balay, Satish <balay at mcs.anl.gov>
> > wrote:
> > > > Mark,
> > > > Can you try the fix in branch balay/fix-mpiexec-shell-escape and see
> > if it
> > > > works?
> > > > Satish
> > > > On Wed, 25 Sep 2019, Balay, Satish via petsc-dev wrote:
> > > > > Mark,
> > > > > Can you send configure.log from mark/fix-cuda-with-gamg-pintocpu
> > branch?
> > > > > Satish
> > > > > > I double checked that a clean build of your (master) branch has
> > this
> > > > error
> > > > > > by my branch (mark/fix-cuda-with-gamg-pintocpu), which may include
> > > > stuff
> > > > > > from Barry that is not yet in master, works.
> > > > > > On Wed, Sep 25, 2019 at 5:26 AM Karl Rupp via petsc-dev <
> > > > > > petsc-dev at mcs.anl.gov> wrote:
> > > > > > > On 9/25/19 11:12 AM, Mark Adams via petsc-dev wrote:
> > > > > > > > I am using karlrupp/fix-cuda-streams, merged with master, and I
> > > > get this
> > > > > > > > error:
> > > > > > > > Could not execute "['jsrun -g\\ 1 -c\\ 1 -a\\ 1
> > --oversubscribe -n
> > > > 1
> > > > > > > > printenv']":
> > > > > > > > Error, invalid argument: 1
> > > > > > > > My branch mark/fix-cuda-with-gamg-pintocpu seems to work but I
> > did
> > > > edit
> > > > > > > > the jsrun command but Karl's branch still fails. (SUMMIT was
> > down
> > > > today
> > > > > > > > so there could have been updates).
> > > > > > > > Any suggestions?
> > > > > > > Looks very much like a systems issue to me.
> > > > > > > Best regards,
> > > > > > > Karli
