[petsc-dev] error with karlrupp/fix-cuda-streams
    Mark Adams
    mfadams at lbl.gov
    Wed Sep 25 13:08:20 CDT 2019
On Wed, Sep 25, 2019 at 12:44 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> Can you retry with updated balay/fix-mpiexec-shell-escape branch?
> current mpiexec interface/code in petsc is messy.
> Its primarily needed for the test suite. But then - you can't easily
> run the test suite on machines like summit.
> Also - it assumes mpiexec provided supports '-n 1'. However if one
> provides non-standard mpiexec such as --with-mpiexec="jsrun -g 1" -
> what is the appropriate thing here?
jsrun does take -n. It just has other args. I am trying to check if it
requires other args. I thought it did but let me check.
> And then configure needs to run some binaries for some checks - here
> perhaps '-n 1' doesn't matter. [MPICH defaults to 1, OpenMPI defaults
> to ncore]. So perhaps mpiexec is required for this purpose on summit?
> And then there is this code to escape spaces in path - for
> windows. [but we have to make sure this is not in code-path for user
> specified --with-mpiexec="jsrun -g 1"
> Satish
> On Wed, 25 Sep 2019, Mark Adams via petsc-dev wrote:
> > No luck,
> > On Wed, Sep 25, 2019 at 10:01 AM Balay, Satish <balay at mcs.anl.gov>
> wrote:
> > > Mark,
> > > Can you try the fix in branch balay/fix-mpiexec-shell-escape and see
> if it
> > > works?
> > > Satish
> > > On Wed, 25 Sep 2019, Balay, Satish via petsc-dev wrote:
> > > > Mark,
> > > > Can you send configure.log from mark/fix-cuda-with-gamg-pintocpu
> branch?
> > > > Satish
> > > > > I double checked that a clean build of your (master) branch has
> this
> > > error
> > > > > by my branch (mark/fix-cuda-with-gamg-pintocpu), which may include
> > > stuff
> > > > > from Barry that is not yet in master, works.
> > > > > On Wed, Sep 25, 2019 at 5:26 AM Karl Rupp via petsc-dev <
> > > > > petsc-dev at mcs.anl.gov> wrote:
> > > > > > On 9/25/19 11:12 AM, Mark Adams via petsc-dev wrote:
> > > > > > > I am using karlrupp/fix-cuda-streams, merged with master, and I
> > > get this
> > > > > > > error:
> > > > > > > Could not execute "['jsrun -g\\ 1 -c\\ 1 -a\\ 1
> --oversubscribe -n
> > > 1
> > > > > > > printenv']":
> > > > > > > Error, invalid argument:  1
> > > > > > > My branch mark/fix-cuda-with-gamg-pintocpu seems to work but I
> did
> > > edit
> > > > > > > the jsrun command but Karl's branch still fails. (SUMMIT was
> down
> > > today
> > > > > > > so there could have been updates).
> > > > > > > Any suggestions?
> > > > > > Looks very much like a systems issue to me.
> > > > > > Best regards,
> > > > > > Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190925/d9dc2076/attachment.html>
