[petsc-dev] It would be really nice if you could run a single job on the pipeline with a branch
Smith, Barry F. bsmith at mcs.anl.gov
Sun Sep 22 23:34:34 CDT 2019
> On Sep 22, 2019, at 11:26 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> Even-though a fix addresses a breakage in a single build - that change
> could break other things so its generally best to run a full test.
  Sure before a merge we want everything tested but when one is iterating on a single bug it would be a much better use of resources
> However if I need to run a single (or a few) test(s) - I would do [not
> an elegant solution you are looking for]:
> - start a new pipeline with the fix
> - cancel this pipeline
> - restart only the selected runs [within this pipeline]
   YES!
> The status in the MR will reflect that the pipeline failed [due to all the other canceled jobs]
> Satish
> On Mon, 23 Sep 2019, Smith, Barry F. via petsc-dev wrote:
>>   When you fix something on a branch that broke a particular job in gitlab-ci it would be nice to be able to run that single job on the updated branch instead of having to submit an entirely new pipeline
>>   Does this exist? Should this be requested in gitlab-ci issues?  Could we make a work around where we hack .gitlab-ci.yml based on a variable to return immediately except on the one truly desired job?
