[petsc-dev] MatMult on Summit
Smith, Barry F.
bsmith at mcs.anl.gov
Sun Sep 22 09:38:15 CDT 2019
Ok, thanks. Then one has to be careful in HPC when using the term so each time it is used everyone in the conversation knows which one it is referring to.
> On Sep 22, 2019, at 8:33 AM, Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>>> Jed,
>>>> What does latency as a function of message size mean? It is in the plots
>>> It's just the wall-clock time to ping-pong a message of that size. All
>>> the small sizes take the same amount of time (i.e., the latency), then
>>> transition to being network bandwidth limited for large sizes.
>> Thanks, this is fine for the small size. But he has the graph up to
>> size 1000000 and the plotted values change for larger sizes, surely
>> for 1000000 the time is a combination of latency and bandwidth?
>> Isn't calling it latency a misnomer, or do people use this
>> inconsistent terminology when doing ping-pongs?
> Latency of an operation is just how long from when you initiate it until
> it completes. Latency in a performance model, such as LogP, is additive
> with other factors (like bandwidth and compute throughput).
