[petsc-dev] MatMult on Summit
Jed Brown
jed at jedbrown.org
Sun Sep 22 08:33:54 CDT 2019
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>> Jed,
>>> What does latency as a function of message size mean? It is in the plots
>> It's just the wall-clock time to ping-pong a message of that size. All
>> the small sizes take the same amount of time (i.e., the latency), then
>> transition to being network bandwidth limited for large sizes.
> Thanks, this is fine for the small size. But he has the graph up to
> size 1000000 and the plotted values change for larger sizes, surely
> for 1000000 the time is a combination of latency and bandwidth?
> Isn't calling it latency a misnomer, or do people use this
> inconsistent terminology when doing ping-pongs?
Latency of an operation is just how long from when you initiate it until
it completes. Latency in a performance model, such as LogP, is additive
with other factors (like bandwidth and compute throughput).
