[petsc-dev] MatMult on Summit
Jed Brown
jed at jedbrown.org
Sat Sep 21 23:43:53 CDT 2019
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> Jed,
> What does latency as a function of message size mean? It is in the plots
It's just the wall-clock time to ping-pong a message of that size. All
the small sizes take the same amount of time (i.e., the latency), then
transition to being network bandwidth limited for large sizes.
>> On Sep 21, 2019, at 11:15 PM, Jed Brown via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
>> Karl Rupp via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>>> Hi Junchao,
>>> thanks, these numbers are interesting.
>>> Do you have an easy way to evaluate the benefits of a CUDA-aware MPI vs.
>>> a non-CUDA-aware MPI that still keeps the benefits of your
>>> packing/unpacking routines?
>>> I'd like to get a feeling of where the performance gains come from. Is
>>> it due to the reduced PCI-Express transfer
>> It's NVLink, not PCI-express.
>> I wonder if the single-node latency bugs on AC922 are related to these
>> weird performance results.
>> https://docs.google.com/spreadsheets/d/1amFJIbpvs9oJcUc-WntsFHO_C0LE7xFJeor-oElt0LY/edit#gid=0
