[petsc-dev] MatMult on Summit
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Sat Sep 21 23:22:23 CDT 2019
  Jed,
  What does latency as a function of message size mean?   It is in the plots
> On Sep 21, 2019, at 11:15 PM, Jed Brown via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> Karl Rupp via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>> Hi Junchao,
>> thanks, these numbers are interesting.
>> Do you have an easy way to evaluate the benefits of a CUDA-aware MPI vs.
>> a non-CUDA-aware MPI that still keeps the benefits of your
>> packing/unpacking routines?
>> I'd like to get a feeling of where the performance gains come from. Is
>> it due to the reduced PCI-Express transfer
> It's NVLink, not PCI-express.
> I wonder if the single-node latency bugs on AC922 are related to these
> weird performance results.
> https://docs.google.com/spreadsheets/d/1amFJIbpvs9oJcUc-WntsFHO_C0LE7xFJeor-oElt0LY/edit#gid=0
