[petsc-dev] test harness: output of actually executed command for V=1 gone?
Jed Brown
jed at jedbrown.org
Fri Sep 20 21:53:54 CDT 2019
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>> Satish and Barry: Do we need the Error codes or can I revert to previous functionality?
> I think it is important to display the error codes.
> How about displaying at the bottom how to run the broken tests? You already show how to run them with the test harness, you could also print how to run them directly? Better then mixing it up with the TAP output?
How about a target for it?
make -f gmakefile show-test search=abcd
We already have print-test, which might more accurately be named ls-test.
