[petsc-dev] test harness: output of actually executed command for V=1 gone?
Smith, Barry F.
bsmith at mcs.anl.gov
Fri Sep 20 21:47:54 CDT 2019
> On Sep 20, 2019, at 4:18 PM, Scott Kruger via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> On 9/20/19 2:49 PM, Jed Brown wrote:
>> Hapla Vaclav via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>>> On 20 Sep 2019, at 19:59, Scott Kruger <kruger at txcorp.com<mailto:kruger at txcorp.com>> wrote:
>>> On 9/20/19 10:44 AM, Hapla Vaclav via petsc-dev wrote:
>>> I was used to copy the command actually run by test harness, change to example's directory and paste the command (just changing one .. to ., e.g. ../ex1 to ./ex1).
>>> Is this output gone? Bad news. I think there should definitely be an option to quickly reproduce the test run to work on failing tests.
>>> I only modified the V=0 option to suppress the TAP 'ok' output.
>>> I think you are referring to the 'not ok' now giving the error code instead of the cmd which is now true regardless of V. This was suggested by others. I defer to the larger group on what's desired here.
>>> Note that is sometimes tedious to deduce the whole command line from the test declarations, for example because of multiple args: lines.
>>> Personally, I recommend just cd'ing into the test directory and running the scripts by hand.
>>> For example:
>>> cd $PETSC_ARCH/tests/ksp/ksp/examples/tests/runex22
>>> cat ksp_ksp_tests-ex22_1.sh
>>> mpiexec -n 1 ../ex22 > ex22_1.tmp 2> runex22.err
>>> OK, this takes a bit more time but does to job.
>> That's yucky. I think we should have an option to print the command(s)
>> that would be run, one line per expanded {{a b c}}, so we can copy-paste
>> into the terminal with only one step of indirection.
> Ugh. I'm dealing with bash at this level - not python.
> Satish and Barry: Do we need the Error codes or can I revert to previous functionality?
I think it is important to display the error codes.
How about displaying at the bottom how to run the broken tests? You already show how to run them with the test harness, you could also print how to run them directly? Better then mixing it up with the TAP output?
Barry
> Scott
> Tech-X Corporation kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
> Boulder, CO 80303 Fax: (303) 448-7756
