[petsc-dev] Configure hangs on Summit
Mills, Richard Tran rtmills at anl.gov
Fri Sep 20 20:59:42 CDT 2019
Hi Junchao,
Glad you've found a workaround, but I don't know why you are hitting this problem. The last time I built PETSc on Summit (just a couple days ago), I didn't have this problem. I'm working from the example template that's in the PETSc repo at config/examples/arch-olcf-summit-opt.py.
Can you point me to your configure script on Summit so I can try to reproduce your problem?
--Richard
On 9/20/19 4:25 PM, Zhang, Junchao via petsc-dev wrote:
Satish's trick --with-mpiexec=/bin/true solved the problem.  Thanks.
--Junchao Zhang
On Fri, Sep 20, 2019 at 3:50 PM Junchao Zhang <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> wrote:
My configure hangs on Summit at
  TESTING: configureMPIEXEC from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:170)
On the machine one has to use script to submit jobs. So why do we need configureMPIEXEC? Do I need to use --with-batch? I remember we removed that.
--Junchao Zhang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190921/5b262c6f/attachment.html>
