[petsc-dev] Configure hangs on Summit
Zhang, Junchao jczhang at mcs.anl.gov
Fri Sep 20 16:25:18 CDT 2019
Satish's trick --with-mpiexec=/bin/true solved the problem.  Thanks.
--Junchao Zhang
On Fri, Sep 20, 2019 at 3:50 PM Junchao Zhang <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> wrote:
My configure hangs on Summit at
  TESTING: configureMPIEXEC from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:170)
On the machine one has to use script to submit jobs. So why do we need configureMPIEXEC? Do I need to use --with-batch? I remember we removed that.
--Junchao Zhang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190920/89efd7fe/attachment.html>
