[petsc-dev] test harness: output of actually executed command for V=1 gone?
Scott Kruger
kruger at txcorp.com
Fri Sep 20 16:18:51 CDT 2019
On 9/20/19 2:49 PM, Jed Brown wrote:
> Hapla Vaclav via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>> On 20 Sep 2019, at 19:59, Scott Kruger <kruger at txcorp.com<mailto:kruger at txcorp.com>> wrote:
>> On 9/20/19 10:44 AM, Hapla Vaclav via petsc-dev wrote:
>> I was used to copy the command actually run by test harness, change to example's directory and paste the command (just changing one .. to ., e.g. ../ex1 to ./ex1).
>> Is this output gone? Bad news. I think there should definitely be an option to quickly reproduce the test run to work on failing tests.
>> I only modified the V=0 option to suppress the TAP 'ok' output.
>> I think you are referring to the 'not ok' now giving the error code instead of the cmd which is now true regardless of V. This was suggested by others. I defer to the larger group on what's desired here.
>> Note that is sometimes tedious to deduce the whole command line from the test declarations, for example because of multiple args: lines.
>> Personally, I recommend just cd'ing into the test directory and running the scripts by hand.
>> For example:
>> cd $PETSC_ARCH/tests/ksp/ksp/examples/tests/runex22
>> cat ksp_ksp_tests-ex22_1.sh
>> mpiexec -n 1 ../ex22 > ex22_1.tmp 2> runex22.err
>> OK, this takes a bit more time but does to job.
> That's yucky. I think we should have an option to print the command(s)
> that would be run, one line per expanded {{a b c}}, so we can copy-paste
> into the terminal with only one step of indirection.
Ugh. I'm dealing with bash at this level - not python.
Satish and Barry: Do we need the Error codes or can I revert to
previous functionality?
Scott
Tech-X Corporation kruger at txcorp.com
5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
Boulder, CO 80303 Fax: (303) 448-7756
