[petsc-dev] test harness: output of actually executed command for V=1 gone?
Jed Brown jed at jedbrown.org
Fri Sep 20 15:49:52 CDT 2019
Hapla  Vaclav via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> On 20 Sep 2019, at 19:59, Scott Kruger <kruger at txcorp.com<mailto:kruger at txcorp.com>> wrote:
> On 9/20/19 10:44 AM, Hapla Vaclav via petsc-dev wrote:
> I was used to copy the command actually run by test harness, change to example's directory and paste the command (just changing one .. to ., e.g. ../ex1 to ./ex1).
> Is this output gone? Bad news. I think there should definitely be an option to quickly reproduce the test run to work on failing tests.
> I only modified the V=0 option to suppress the TAP 'ok' output.
> I think you are referring to the 'not ok' now giving the error code instead of the cmd which is now true regardless of V.  This was suggested by others.  I defer to the larger group on what's desired here.
> Note that is sometimes tedious to deduce the whole command line from the test declarations, for example because of multiple args: lines.
> Personally, I recommend just cd'ing into the test directory and running the scripts by hand.
> For example:
> cd $PETSC_ARCH/tests/ksp/ksp/examples/tests/runex22
> cat ksp_ksp_tests-ex22_1.sh
> mpiexec  -n 1 ../ex22   > ex22_1.tmp 2> runex22.err
> OK, this takes a bit more time but does to job.
That's yucky.  I think we should have an option to print the command(s)
that would be run, one line per expanded {{a b c}}, so we can copy-paste
into the terminal with only one step of indirection.
