[petsc-dev] test harness: output of actually executed command for V=1 gone?
    Hapla  Vaclav
    vaclav.hapla at erdw.ethz.ch
    Fri Sep 20 11:44:59 CDT 2019
I was used to copy the command actually run by test harness, change to example's directory and paste the command (just changing one .. to ., e.g. ../ex1 to ./ex1).
Is this output gone? Bad news. I think there should definitely be an option to quickly reproduce the test run to work on failing tests.
Note that is sometimes tedious to deduce the whole command line from the test declarations, for example because of multiple args: lines.
Vaclav
