[petsc-dev] Master broken after changes to PetscSection headers
Balay, Satish balay at mcs.anl.gov
Thu Sep 19 18:45:50 CDT 2019
all tests cleared [including valgrind] except for the super slow 'Apple laptop' build - so will merge now
Satish
On Thu, 19 Sep 2019, Smith, Barry F. via petsc-dev wrote:
>   Master is already broken so you might as well merge since you can't break it more than I did.
>   Barry
> > On Sep 19, 2019, at 4:48 PM, Zhang, Junchao via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> > Could this problem be fixed right now? It shows up in stage-1 tests and block further tests.
> > --Junchao Zhang
> > On Thu, Sep 19, 2019 at 4:15 AM Lisandro Dalcin via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> > The warnings below are from a C build. A C++ build fails right away.
> > We need to `#include <petscsection.h>` somewhere in the public headers, at least such that  `#include <petsc.h>` in user code works.
> > $ git grep petscsection include/
> > include/petsc/private/sectionimpl.h:#include <petscsection.h>
> > include/petscis.h:#include <petscsectiontypes.h>
> > include/petscsection.h:#include <petscsectiontypes.h>
> > /home/devel/petsc/dev/src/snes/utils/convest.c: In function ‘PetscConvEstGetConvRate’:
> > /home/devel/petsc/dev/src/snes/utils/convest.c:293:14: warning: implicit declaration of function ‘PetscSectionGetField’; did you mean ‘PetscSectionVecView’? [-Wimplicit-function-declaration]
> >   293 |       ierr = PetscSectionGetField(s, f, &fs);CHKERRQ(ierr);
> >       |              PetscSectionVecView
> > /home/devel/petsc/dev/src/snes/utils/convest.c:294:14: warning: implicit declaration of function ‘PetscSectionGetConstrainedStorageSize’ [-Wimplicit-function-declaration]
> >   294 |       ierr = PetscSectionGetConstrainedStorageSize(fs, &lsize);CHKERRQ(ierr);
> > Lisandro Dalcin
> > Research Scientist
> > Extreme Computing Research Center (ECRC)
> > King Abdullah University of Science and Technology (KAUST)
> > http://ecrc.kaust.edu.sa/
