[petsc-dev] Master broken after changes to PetscSection headers
    Balay, Satish
    balay at mcs.anl.gov
    Thu Sep 19 17:03:34 CDT 2019
The fixes are at
https://gitlab.com/petsc/petsc/pipelines/83247427
The tests are not yet complete - so I'm hesitating to merge.
with osx test boxes misbehaving - its taking longer.  I might have to
disable some of the osx-tests [and opensolaris is also slow]
Or I should  might go ahead and merge this one before it completes..
Satish
On Thu, 19 Sep 2019, Zhang, Junchao via petsc-dev wrote:
> Could this problem be fixed right now? It shows up in stage-1 tests and block further tests.
> --Junchao Zhang
> On Thu, Sep 19, 2019 at 4:15 AM Lisandro Dalcin via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
> The warnings below are from a C build. A C++ build fails right away.
> We need to `#include <petscsection.h>` somewhere in the public headers, at least such that  `#include <petsc.h>` in user code works.
> $ git grep petscsection include/
> include/petsc/private/sectionimpl.h:#include <petscsection.h>
> include/petscis.h:#include <petscsectiontypes.h>
> include/petscsection.h:#include <petscsectiontypes.h>
> /home/devel/petsc/dev/src/snes/utils/convest.c: In function ‘PetscConvEstGetConvRate’:
> /home/devel/petsc/dev/src/snes/utils/convest.c:293:14: warning: implicit declaration of function ‘PetscSectionGetField’; did you mean ‘PetscSectionVecView’? [-Wimplicit-function-declaration]
>   293 |       ierr = PetscSectionGetField(s, f, &fs);CHKERRQ(ierr);
>       |              PetscSectionVecView
> /home/devel/petsc/dev/src/snes/utils/convest.c:294:14: warning: implicit declaration of function ‘PetscSectionGetConstrainedStorageSize’ [-Wimplicit-function-declaration]
>   294 |       ierr = PetscSectionGetConstrainedStorageSize(fs, &lsize);CHKERRQ(ierr);
> Lisandro Dalcin
> Research Scientist
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
