[petsc-dev] Master broken after changes to PetscSection headers
Stefano Zampini
stefano.zampini at gmail.com
Thu Sep 19 04:27:30 CDT 2019
Lisandro has a point. If someone includes petsc.h, he should be able to use
petscsection stuff. So it has to go somewhere in the public headers
Il Gio 19 Set 2019, 12:26 Matthew Knepley <knepley at gmail.com> ha scritto:
> I pushed the fix to the branch. Can we remerge it?
> Also, I do not understand why tests did not catch this. Its obvious what
> happened. I added that header
> to convert.c instead of convest.c.
> Matt
> On Thu, Sep 19, 2019 at 5:19 AM Stefano Zampini via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> How come this was not caught by the tests? I think we have tests with
>> -Werror
>> Il Gio 19 Set 2019, 12:15 Lisandro Dalcin via petsc-dev <
>> petsc-dev at mcs.anl.gov> ha scritto:
>>> The warnings below are from a C build. A C++ build fails right away.
>>> We need to `#include <petscsection.h>` somewhere in the public headers,
>>> at least such that `#include <petsc.h>` in user code works.
>>> $ git grep petscsection include/
>>> include/petsc/private/sectionimpl.h:#include <petscsection.h>
>>> include/petscis.h:#include <petscsectiontypes.h>
>>> include/petscsection.h:#include <petscsectiontypes.h>
>>> /home/devel/petsc/dev/src/snes/utils/convest.c: In function
>>> ‘PetscConvEstGetConvRate’:
>>> /home/devel/petsc/dev/src/snes/utils/convest.c:293:14: warning: implicit
>>> declaration of function ‘PetscSectionGetField’; did you mean
>>> ‘PetscSectionVecView’? [-Wimplicit-function-declaration]
>>> 293 | ierr = PetscSectionGetField(s, f, &fs);CHKERRQ(ierr);
>>> | PetscSectionVecView
>>> /home/devel/petsc/dev/src/snes/utils/convest.c:294:14: warning: implicit
>>> declaration of function ‘PetscSectionGetConstrainedStorageSize’
>>> 294 | ierr = PetscSectionGetConstrainedStorageSize(fs,
>>> &lsize);CHKERRQ(ierr);
>>> Lisandro Dalcin
>>> Research Scientist
>>> Extreme Computing Research Center (ECRC)
>>> King Abdullah University of Science and Technology (KAUST)
>>> http://ecrc.kaust.edu.sa/
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190919/e6b65e41/attachment.html>
