[petsc-dev] gitlab migration for pull request
Balay, Satish
balay at mcs.anl.gov
Wed Sep 11 09:02:31 CDT 2019
On Wed, 11 Sep 2019, Jed Brown via petsc-dev wrote:
> Please fork the repository on GitLab
> (https://gitlab.com/petsc/petsc/-/forks/new) and push your branch to the
> fork, then make a merge request. If you become a regular contributor,
> we can give you push privileges to the main repository.
> Pierre Gosselet via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> > Dear all,
> > I am sorry, I have not understood how to migrate Push Request from
> > bitbucket to gitlab.
> > I think I need the equivalent of
> > git remote set-url origin https://gitlab.com/petsc/petsc.git
> > applied to my development branch (I see that my branch's remote is
> > incorrect in .git/config).
> You can fix that using git branch --set-upstream-to (see the man page).
BTW: I normally do 'git fetch -p' - this updates all remote references
[and deletes origin/* references that don't exist on the remote repo].
And then I can push any local branches that I need - similar to a newly created branch. i.e
git push -u origin branch-name
Satish
> > Or am I supposed to make a fresh fork and MR from gitlab ?
> > thank you for your help.
> > best regards
> > pierre
> > Pierre Gosselet
> > CR CNRS (research agent)
> > LMT -- ENS Paris-Saclay/UMR8535
> > 61 av. du président Wilson, 94235 CACHAN
> > tel: +33 1 47405333
