[petsc-dev] I think the test system is broken in master
Smith, Barry F.
bsmith at mcs.anl.gov
Wed Oct 23 22:34:23 CDT 2019
The test system really has to dump all the output including stderr to GitLab; the stack frames etc. Drop just little tidbits without all the error output is worse than users who cut and paste one line from configure.log and expect it to help. I don't know how you decide to redirect stuff and pick and chose where it goes but it all needs to come out as one ASCII stream to GitLab.
Barry
> On Oct 23, 2019, at 2:54 PM, Matthew Knepley via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> I just rebased my branch on master, and now with REPLACE=1 I am getting
> not ok diff-ksp_ksp_tutorials-ex70_fetidp # Error code: 1
> # 1,2d0
> # < DMSWARM_PIC: Using method CellDM->LocatePoints
> # < DMSWARM_PIC: Using method CellDM->GetNeigbors
> # mv'ing ex70_fetidp.tmp --> /var/folders/hk/tc1pd0g57l78rpt0lttc1sfh0000gn/T/petscdiff.XXXXXX.fjHMBkGr
> I would really liked to get this fixed as fast as possible since it will hold up all development.
> Thanks,
> Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
