[petsc-dev] [Suggestion] Configure QOL Improvements
    Matthew Knepley
    knepley at gmail.com
    Wed Oct 23 16:03:26 CDT 2019
On Wed, Oct 23, 2019 at 4:59 PM Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > That is an unreliable check for Z. You would not eliminate the case
> > where you give --with-Z, but the check fails, so Z is not available,
> > but you do not find out until checking X or Y.
> You can verify that Z works in a fraction of a second, but building X
> may take minutes.  Work bottom up, verify everything that is given
> before building anything.
That is exactly what we do now. What are you talking about?
  Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191023/c1adb4a3/attachment.html>
