[petsc-dev] Wrong "failed tests" command
Pierre Jolivet
pierre.jolivet at enseeiht.fr
Mon Oct 21 12:30:37 CDT 2019
Hello,
In this pipeline build log, https://gitlab.com/petsc/petsc/-/jobs/326525063 <https://gitlab.com/petsc/petsc/-/jobs/326525063>, it shows that I can rerun failed tests using the following command:
/usr/bin/make -f gmakefile test globsearch='mat_tests-ex128_1 mat_tests-ex37_nsize-2_mat_type-mpibaij_mat_block_size mat_tests-ex37_nsize-1_mat_type-mpibaij_mat_block_size mat_tests-ex128_2 mat_tests-ex37_nsize-2_mat_type-baij_mat_block_size mat_tests-ex37_nsize-1_mat_type-baij_mat_block_size mat_tests-ex30_4 mat_tests-ex37_nsize-2_mat_type-sbaij_mat_block_size mat_tests-ex18_* mat_tests-ex76_3 mat_tests-ex37_nsize-2_mat_type-mpisbaij_mat_block_size mat_tests-ex37_nsize-1_mat_type-sbaij_mat_block_size’
If used, this command does not run any of the mat_test-ex37* tests.
Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191021/631aa189/attachment.html>
