[petsc-dev] "participants" on gitlab
Balay, Satish
balay at mcs.anl.gov
Mon Oct 21 11:01:03 CDT 2019
On Mon, 21 Oct 2019, Zhang, Hong via petsc-dev wrote:
> How is the list of participants determined when a MR is created on gitlab? It seems to include everybody by default. Is there any way to shorten the list? Ideally only the participants involved in the particular MR should be picked. Note that currently there is a huge gap between the ''Participate'' and ''On mention'' levels in the notification settings. With the former, I get spammed with notifications whenever a new MR is created. With the later, I won’t receive any notification (even someone replied my comments) unless explicitly @ by someone.
> Hong (Mr.)
Copy/pasting some prior notes from Scott and Alp on this..
Satish
On Mon, 30 Sep 2019, Dener, Alp wrote:
> It isn’t doing what it should be, but I’m keeping it at “Participate” to make sure I don’t miss any MRs that I need to be looking at.
> In the meantime, there’s an active ongoing discussion about this notification issue here: https://gitlab.com/gitlab-org/gitlab/issues/4816
> On September 26, 2019 at 11:37:18 AM, Alp Dener (adener at anl.gov) wrote:
> I switched it to “Participate” for the developer group. I previously had my global setting at “participate” and developer set to “global” and that didn’t seem to work, but maybe there’s
> a bug that requires developer to be specifically set. Hopefully this’ll work.
On Thu, 12 Sep 2019, Scott Kruger wrote:
> Here's what I did:
> Settings -> Notifications -> developers + Participate
> The default is "Global". "Participate" is what I'm using now.
> There is a "Custom", but it confuses me since it says you can
> use it to match "Participate", but you can't do something like:
> Email all new issues, but only show me the MR's I am mentioned
> in or own.
