[petsc-dev] Why no SpGEMM support in AIJCUSPARSE and AIJVIENNACL?
Karl Rupp
rupp at iue.tuwien.ac.at
Wed Oct 2 22:59:45 CDT 2019
Hi Richard,
CPU spGEMM is about twice as fast even on the GPU-friendly case of a
single rank: http://viennacl.sourceforge.net/viennacl-benchmarks-spmm.html
I agree that it would be good to have a GPU-MatMatMult for the sake of
experiments. Under these performance constraints it's not top priority,
though.
Best regards,
Karli
On 10/3/19 12:00 AM, Mills, Richard Tran via petsc-dev wrote:
> Fellow PETSc developers,
> I am wondering why the AIJCUSPARSE and AIJVIENNACL matrix types do not
> support the sparse matrix-matrix multiplication (SpGEMM, or MatMatMult()
> in PETSc parlance) routines provided by cuSPARSE and ViennaCL,
> respectively. Is there a good reason that I shouldn't add those? My
> guess is that support was not added because SpGEMM is hard to do well on
> a GPU compared to many CPUs (it is hard to compete with, say, Intel Xeon
> CPUs with their huge caches) and it has been the case that one would
> generally be better off doing these operations on the CPU. Since the
> trend at the big supercomputing centers seems to be to put more and more
> of the computational power into GPUs, I'm thinking that I should add the
> option to use the GPU library routines for SpGEMM, though. Is there some
> good reason to *not* do this that I am not aware of? (Maybe the CPUs are
> better for this even on a machine like Summit, but I think we're at the
> point that we should at least be able to experimentally verify this.)
> --Richard
