[petsc-dev] KSP in DMPlex
    Faibussowitsch, Jacob
    jfaibussowitsch at anl.gov
    Thu Nov 14 12:30:38 CST 2019
Hello,
So I am trying to make a simple 5 pt stencil finite difference laplacian operator (https://akmitra.public.iastate.edu/aero361/design_web/Laplace.pdf) work on a dmplex mesh, but all of the examples that I have found in ksp/examples/tutorials all use DMDA. The only way that I have managed to get the KSP to even run is by creating the operator matrix myself by hand. The workflow for the working implementation is as follows:
DMPlexMakeBoxMesh -> KSPCreate -> KSPsetDM -> KSPDeactiveDM -> Make the matrix by hand ->  KSPSetOperator(matrix) -> KSPSetComputeRHS -> Solve
Given that I tether KSP to the DM by KSPSetDM, but then immediately deactivate it (because then it complains about mallocs), this doesn’t work when reading in an actual unstructured mesh. Does KSP just not support dmplex?
Best,
Jacob
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191114/2cebaaf6/attachment.html>
