[petsc-dev] Parmetis bug
    Fande Kong
    fdkong.jd at gmail.com
    Sun Nov 10 19:31:14 CST 2019
Valgrind info:
==32155== Invalid read of size 4
==32155==    at 0x885F62F: libmetis__CreateCoarseGraphNoMask (coarsen.c:879)
==32155==    by 0x885E2B9: libmetis__CreateCoarseGraph (coarsen.c:636)
==32155==    by 0x885CA49: libmetis__Match_RM (coarsen.c:262)
==32155==    by 0x885BFBD: libmetis__CoarsenGraph (coarsen.c:55)
==32155==    by 0x8869A4C: libmetis__MultilevelBisect (pmetis.c:240)
==32155==    by 0x88696F6: libmetis__MlevelRecursiveBisection (pmetis.c:183)
==32155==    by 0x88698D7: libmetis__MlevelRecursiveBisection (pmetis.c:207)
==32155==    by 0x886951E: METIS_PartGraphRecursive (pmetis.c:133)
==32155==    by 0x885650B: libmetis__InitKWayPartitioning (kmetis.c:194)
==32155==    by 0x8856147: libmetis__MlevelKWayPartitioning (kmetis.c:121)
==32155==    by 0x8855FD3: METIS_PartGraphKway (kmetis.c:71)
==32155==    by 0x85E7611: libparmetis__PartitionSmallGraph (weird.c:478)
==32155==    by 0x85D00F3: ParMETIS_V3_PartKway (kmetis.c:91)
==32155==    by 0x5515C19: MatPartitioningApply_Parmetis_Private
(pmetis.c:147)
==32155==    by 0x5516F7D: MatPartitioningApply_Parmetis (pmetis.c:221)
==32155==    by 0x550DD7F: MatPartitioningApply (partition.c:332)
==32155==    by 0x6387033: PCGAMGCreateLevel_GAMG (gamg.c:226)
==32155==    by 0x638BCA5: PCSetUp_GAMG (gamg.c:593)
==32155==    by 0x64746B1: PCSetUp (precon.c:894)
==32155==    by 0x65D388A: KSPSetUp (itfunc.c:377)
==32155==  Address 0xee2502c is 0 bytes after a block of size 284 alloc'd
==32155==    at 0x4C2AB80: malloc (in
/usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==32155==    by 0x8820179: gk_malloc (memory.c:147)
==32155==    by 0x883D92B: libmetis__imalloc (gklib.c:24)
==32155==    by 0x885BF6A: libmetis__CoarsenGraph (coarsen.c:46)
(pmetis.c:147)
==32155==
==32155== Conditional jump or move depends on uninitialised value(s)
==32155==    at 0x885F651: libmetis__CreateCoarseGraphNoMask (coarsen.c:880)
(pmetis.c:147)
==32155==
==32155== Use of uninitialised value of size 8
==32155==    at 0x885F6F2: libmetis__CreateCoarseGraphNoMask (coarsen.c:886)
(pmetis.c:147)
==32155==
==32155==    at 0x885F710: libmetis__CreateCoarseGraphNoMask (coarsen.c:886)
(pmetis.c:147)
==32155==
==32155==    at 0x885F392: libmetis__CreateCoarseGraphNoMask (coarsen.c:856)
(pmetis.c:147)
(pmetis.c:147)
==32155==
==32155==    by 0x885D3CC: libmetis__Match_SHEM (coarsen.c:403)
==32155==    by 0x885BFD2: libmetis__CoarsenGraph (coarsen.c:57)
(pmetis.c:147)
==32155==  Address 0xee27524 is 8 bytes after a block of size 76 alloc'd
==32155==    by 0x88607CF: libmetis__SetupCoarseGraph (coarsen.c:1107)
==32155==    by 0x885F16A: libmetis__CreateCoarseGraphNoMask (coarsen.c:826)
(pmetis.c:147)
==32155==
(pmetis.c:147)
==32155==  Address 0xee274cc is 4 bytes before a block of size 76 alloc'd
(pmetis.c:147)
==32155==
On Sun, Nov 10, 2019 at 2:24 PM Mark Adams <mfadams at lbl.gov> wrote:
> Fande, It looks to me like this branch in ParMetis must be taken to
> trigger this error. First *Match_SHEM* and then CreateCoarseGraphNoMask.
>    /* determine which matching scheme you will use */
>     switch (ctrl->ctype) {
>       case METIS_CTYPE_RM:
>         Match_RM(ctrl, graph);
>         break;
>       case METIS_CTYPE_SHEM:
>         if (eqewgts || graph->nedges == 0)
>         else
> *          Match_SHEM(ctrl, graph);*        break;
>       default:
>         gk_errexit(SIGERR, "Unknown ctype: %d\n", ctrl->ctype);
>   /* Check if the mask-version of the code is a good choice */
>   mask = HTLENGTH;
>   if (cnvtxs < 2*mask || graph->nedges/graph->nvtxs > mask/20) {
>     CreateCoarseGraphNoMask(ctrl, graph, cnvtxs, match);
>     return;
> The actual error is in CreateCoarseGraphNoMask, graph->cmap is too small
> and this gets garbage. parmetis coarsen.c:856:
>     istart = xadj[v];
>     iend   = xadj[v+1];
>     for (j=istart; j<iend; j++) {
> *      k = cmap[adjncy[j]];*      if ((m = htable[k]) == -1) {
>         cadjncy[nedges] = k;
>  Anyway, this is what I have so far,
> Mark
> On Sun, Nov 10, 2019 at 10:34 AM Mark Adams <mfadams at lbl.gov> wrote:
>> Fande, the problem is k below seems to index beyond the end of htable,
>> resulting in a crazy m and a segv on the last line below.
>> I don't have a clean valgrind machine now, that is what is needed if no
>> one has seen anything like this. I could add a test in a MR and get the
>> pipeline to do it.
>> void CreateCoarseGraphNoMask(ctrl_t *ctrl, graph_t *graph, idx_t cnvtxs,
>>          idx_t *match)
>>   idx_t j, k, m, istart, iend, nvtxs, nedges, ncon, cnedges, v, u,
>> dovsize;
>>   idx_t *xadj, *vwgt, *vsize, *adjncy, *adjwgt;
>>   idx_t *cmap, *htable;
>>   idx_t *cxadj, *cvwgt, *cvsize, *cadjncy, *cadjwgt;
>>   graph_t *cgraph;
>> ine
>>   WCOREPUSH;
>>   dovsize = (ctrl->objtype == METIS_OBJTYPE_VOL ? 1 : 0);
>>   IFSET(ctrl->dbglvl, METIS_DBG_TIME,
>> gk_startcputimer(ctrl->ContractTmr));
>>   nvtxs   = graph->nvtxs;
>>   ncon    = graph->ncon;
>>   xadj    = graph->xadj;
>>   vwgt    = graph->vwgt;
>>   vsize   = graph->vsize;
>>   adjncy  = graph->adjncy;
>>   adjwgt  = graph->adjwgt;
>>   cmap    = graph->cmap;
>>   /* Initialize the coarser graph */
>>   cgraph = SetupCoarseGraph(graph, cnvtxs, dovsize);
>>   cxadj    = cgraph->xadj;
>>   cvwgt    = cgraph->vwgt;
>>   cvsize   = cgraph->vsize;
>>   cadjncy  = cgraph->adjncy;
>>   cadjwgt  = cgraph->adjwgt;
>>   htable = iset(cnvtxs, -1, iwspacemalloc(ctrl, cnvtxs));
>>   cxadj[0] = cnvtxs = cnedges = 0;
>>   for (v=0; v<nvtxs; v++) {
>>     if ((u = match[v]) < v)
>>       continue;
>>     ASSERT(cmap[v] == cnvtxs);
>>     ASSERT(cmap[match[v]] == cnvtxs);
>>     if (ncon == 1)
>>       cvwgt[cnvtxs] = vwgt[v];
>>     else
>>       icopy(ncon, vwgt+v*ncon, cvwgt+cnvtxs*ncon);
>>     if (dovsize)
>>       cvsize[cnvtxs] = vsize[v];
>>     nedges = 0;
>>     istart = xadj[v];
>>     iend   = xadj[v+1];
>>         cadjwgt[nedges] = adjwgt[j];
>>         htable[k] = nedges++;
>>       else {
>>         cadjwgt[m] += adjwgt[j];
>> On Sun, Nov 10, 2019 at 1:35 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> On Sat, Nov 9, 2019 at 10:51 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>>> Hi Mark,
>>>> Thanks for reporting this bug. I was surprised because we have
>>>> sufficient heavy tests in moose using partition weights and do not have any
>>>> issue so far.
>>> I have been pounding on this code with elasticity and have not seen this
>>> issue. I am now looking at Lapacianas and I only see it with pretty large
>>> problems. The example below is pretty minimal (eg, it works with 16 cores
>>> and it works with -dm_refine 4). I have reproduced this on Cori, SUMMIT and
>>> my laptop.
>>>> I will take a shot on this.
>>> Thanks, I'll try to take a look at it also. I have seen it in DDT, but
>>> did not dig further. It looked like a typical segv in ParMetis.
>>>> Fande,
>>>> On Sat, Nov 9, 2019 at 3:08 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> snes/ex13 is getting a ParMetis segv with GAMG and coarse grid
>>>>> repartitioning. Below shows the branch and how to run it.
>>>>> I've tried valgrind on Cori but it gives a lot of false positives.
>>>>> I've seen this error in DDT but I have not had a chance to dig and try to
>>>>> fix it. At least I know it has something to do with weights.
>>>>> If anyone wants to take a shot at it feel free. This bug rarely
>>>>> happens.
>>>>> The changes use weights and are just a few lines of code (from 1.5
>>>>> years ago):
>>>>> 12:08 (0455fb9fec...)|BISECTING ~/Codes/petsc$ git bisect bad
>>>>> 0455fb9fecf69cf5cf35948c84d3837e5a427e2e is the first bad commit
>>>>> commit 0455fb9fecf69cf5cf35948c84d3837e5a427e2e
>>>>> Author: Fande Kong <fdkong.jd at gmail.com>
>>>>> Date:   Thu Jun 21 18:21:19 2018 -0600
>>>>>     Let parmetis and ptsotch take edge weights and vertex weights
>>>>>  src/mat/partition/impls/pmetis/pmetis.c | 7 +++++++
>>>>>  src/mat/partition/impls/scotch/scotch.c | 6 +++---
>>>>>  2 files changed, 10 insertions(+), 3 deletions(-)
>>>>> > mpiexec -n 32 ./ex13 -cells 2,4,4, -dm_refine 5 -simplex 0 -dim 3
>>>>> -potential_petscspace_degree 1 -potential_petscspace_order 1 -pc_type gamg
>>>>> -petscpartitioner_type simple -pc_gamg_repartition
>>>>> true -check_pointer_intensity 0
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191110/759e2738/attachment-0001.html>
