[petsc-dev] Documenting types of examples
Matthew Knepley
knepley at gmail.com
Fri May 31 08:15:30 CDT 2019
On Fri, May 31, 2019 at 9:11 AM Patrick Sanan <patrick.sanan at gmail.com>
wrote:
> We only removed the Concepts from the man pages. The Concepts in the
> examples should remain, and are compiled as usual here :
> https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/help.html
> Does that suffice for what you'd like to add?
I think so.
Although right now the hierarchical organization is nonsensical. Why would
there be a "Laplacian" under KSP, and also
at the top level? It should just be tags, like email, so a user can select
the set of tags they are looking for.
Matt
> Am Fr., 31. Mai 2019 um 15:08 Uhr schrieb Matthew Knepley <
> knepley at gmail.com>:
>> How should we document the types of examples we have, now that we removed
>> Concepts?
>> For example, I would like it to be easy to see that I have FEM examples
>> for
>> - Poisson
>> - p-Laplacian
>> - Linear elasticity
>> - Large deformation elasticity
>> - Stokes
>> - variable-viscosity Stokes
>> - Heat equation
>> - Navier-Stokes
>> Where would someone see this? Clearly, we want similar lists for other
>> examples.
>> Thanks,
>> Matt
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190531/5e4ab88d/attachment.html>
