[petsc-dev] Bogus tag
Jed Brown
jed at jedbrown.org
Fri May 3 15:48:57 CDT 2019
"Balay, Satish" <balay at mcs.anl.gov> writes:
> Well this also requires:
> - everyone who pulled this tag to manually delete it from their local clone.
I think the automatically pushing tags issue was resolved a while ago in
Git defaults.
> I don't know if there is a good way to do this. There is 'git fetch --prune-tags'
> - but its not useful if you keep local tags [that you don't intend to push out]
> - and prevent folks from re-pushing this tag (from a clone where this tag is not deleted)
> [I've setup branch permissions at bitbucket to help with this]
> Satish
> On Fri, 3 May 2019, Jed Brown via petsc-dev wrote:
>> Gross. I deleted it.
>> That was created when I was trying to label a PR in the web interface.
>> It didn't work as intended, but I didn't realize it had left behind a
>> Git tag in the repository.
>> Lisandro Dalcin via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>> > $ git branch
>> > * master
>> > $ git describe
>> > WIP-112-g872c329e82
>> > $ git show WIP
>> > tag WIP
>> > Tagger: Jed Brown <jed at 59a2.org>
>> > Date: Wed Apr 24 22:56:11 2019 +0000
>> > Work In Progress (do not merge)
>> > Is there any way we can get rid of that?
>> > Lisandro Dalcin
>> > Research Scientist
>> > Extreme Computing Research Center (ECRC)
>> > King Abdullah University of Science and Technology (KAUST)
>> > http://ecrc.kaust.edu.sa/
