[petsc-dev] Bogus tag
    Balay, Satish
    balay at mcs.anl.gov
    Fri May  3 15:40:38 CDT 2019
Well this also requires:
- everyone who pulled this tag to manually delete it from their local clone.
I don't know if there is a good way to do this. There is 'git fetch --prune-tags'
 - but its not useful if you keep local tags [that you don't intend to push out]
- and prevent folks from re-pushing this tag (from a clone where this tag is not deleted)
[I've setup branch permissions at bitbucket to help with this]
Satish
On Fri, 3 May 2019, Jed Brown via petsc-dev wrote:
> Gross.  I deleted it.
> That was created when I was trying to label a PR in the web interface.
> It didn't work as intended, but I didn't realize it had left behind a
> Git tag in the repository.
> Lisandro Dalcin via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> > $ git branch
> > * master
> > $ git describe
> > WIP-112-g872c329e82
> > $ git show WIP
> > tag WIP
> > Tagger: Jed Brown <jed at 59a2.org>
> > Date:   Wed Apr 24 22:56:11 2019 +0000
> > Work In Progress (do not merge)
> > Is there any way we can get rid of that?
> > Lisandro Dalcin
> > Research Scientist
> > Extreme Computing Research Center (ECRC)
> > King Abdullah University of Science and Technology (KAUST)
> > http://ecrc.kaust.edu.sa/
