[petsc-dev] [petsc-users] Bad memory scaling with PETSc 3.10
Mark Adams mfadams at lbl.gov
Thu Mar 21 18:37:18 CDT 2019
> Could you explain this more by adding some small examples?
Since you are considering implementing all-at-once (four nested loops,
right?) I'll give you my old code.
This code is hardwired for two AMG and for a geometric-AMG, where the
blocks of the R (and hence P) matrices are scaled identities and I only
store the scale. So you ignore those branches. This code also does
equivalent real form complex, so more branches to ignore.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190321/1891005b/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190321/1891005b/attachment-0001.obj>
